Heavy Rain ingress 05 X Type Estate
Hello,
Whilst hunting round the boot for the evasive parking sensor speaker, which is what I think is causing them to not work, I noticed that there has been a huge amount of water ingress into the boot area. Is this a known problem with these cars or do I have a new problem? What can be done to fix this? I notice one of the grommets has been removed from the spare wheel well, which I suspect my be to let the water drain out? There is water everywhere, including all over the Parking Sensor box. Thanks For any help, Stu. |
check all of your seals and make sure the trunk is closing correctly. Jaguar designed the rain gutters to pretty much run down the side of the trunk seals so I would expect that your seals are not seated correctly or have a slit in them
