Key fob circuit board
Hi all,
when I bought my X type from a lovely older lady I was told the spare key fob had a flat battery. Unfortunately its more than that. I've just replaced the battery and the fob didn't work so I took it apart again for a closer look. A part on the circuit board is broken, not something I can fix. So, my questions are; Can I buy just the circuit board? If so will it need to be programmed by a dealer? If not what is my best option? Cheers, Mike P.S. I'm in Australia, south east Victoria |
Use search on main page. Many threads with the answer.
Originally Posted by Dell Gailey
(Post 2054922)
No offence but that's a bold call :) Cheers, Mike. |
It's on main page, X type forum, search, advanced search, input key fob. Short answer is no circuit board is available. You have to buy a replacement key fob with the correct mhz for your country, have it programmed to your car after having tibbe key cut to your car to start it, and program fob (either by dealer, key maker with equipment or by process in forum) to get buttons to work which is separate from the "antennae" programming to start car.
The other option is buy a replacement key, look in forum and online of how to open the fob (not easy and needs care), take your old antennae out and replace in the new fob. This will eliminate having to have it programmed to start the car. The tibbe key still needs to be cut correctly and the buttons programmed by one of the 3 mentioned methods. |
$16 shipped from ebay key blank with remote. I removed remotes from keys and switched them. My X got sold before I programmed remote.
Originally Posted by car5car
(Post 2055187)
The big trick is the security transponder/antenna in the fob. You could possibly buy one of the Ebay fobs, remove the circuit board from it, and install it into your existing fob. The transponder/antenna is located in the same half of the fob as the key. My X-Types are a 2007 and a 2008, I don't know if there's any difference between their fobs and the 2002.
Good luck. |
The transponder is actually a little "pill" looking component in the upper portion of the fob. It can be removed and put into a new fob with tons of CARE. You can't muscle it.
hey mate, inbox me if you need help with your remote/keys. I'm in Melbourne as well.
Thanks for all the replies, Ill have a go at buying a fob with transponder and switching "hard" keys.
Sorry for not replying earlier, "life" got in the way :) Hey Dopey, thanks for the offer and I'll do that if have trouble. Cheers, Mike. |
the key fob pulls apart, the bit with the buttons has the PCB, the PCB's are available for eb*y and can be switched between the two frequencies used. if the key works the lock but not start the car then the transponder needs to be programed, transponder is in the bit with the key blade.
The key fobs I've found on e bay do not support my car, here is a copy and paste:
Item Previewing: Features: - Brand new key case with uncut blade, Internal (buttons / transponder chips / battery) are included - Easy installation, if you use your old remote then there is no programming require - Direct fits, get the blade cut at any locksmith or swap the blade - A perfect replacement for your damaged/worn remote key - FOB does not come with any emblem or logos Specifications Condition: 100% brand new Color: Black Button: 4 Buttons Length: 70mm/2.75" Width: 38mm/1.5" Height: 2mm/0.79" Quantity: 1 piece Fitment: Pls confirm the shape of your remote key is the same as the below pictures showed. Jaguar XJ 2002-2008 Jaguar XJR 2002-2008 Jaguar X-Type 2002 2004-2009 (Not support 2003 Juguar X-Type) Jaguar S-Type 1999-2009 Package Included: 1 x Remote Key with Uncut Blade for JAGUAR Would this be because of the circuit board of transponder? |
Mate, have you sorted this yet? I've been away, so am tardy in replying to your last post. There are plenty of key fobs on eBay in Australia and only 1 provider that I can see has that thing about not supporting 2003 X-Type. All the others do, and I reckon it's one of the other Jags that it doesn't fit. The others all say their key fobs fit, as long as yours looks like the ones shown, and not some other after-market one. Just buy it from China and try it - not much lost but plenty gained on the deal. Remember to check YouTube for the simple programming stuff.
Originally Posted by Yorta2
(Post 2105321)
I must have looked at a dozen or three and I only found a couple that didn't say "2003 not supported" Those ones where double, or more the price, I guess we had slightly different search results. Thanks, Mike. |
To sum things up, I bought a circuit board for a chap in Sydney (Aust) popped it in the fob, paired the fob and it works fine.
Big Thank you to Grant Francis for his help, cheers mate I ouw you a beer or wine :) Mike |
Hi
Originally Posted by dopey
(Post 2055375)
i have an unregistered xseries Jaguar, and need help with my key...I broke my fob, and thought I was doing the right thing when I kept the key and the motherboard and threw the rest out. But it’s not working and ive parked it at a friends house who now wants it moved...and I can’t get it started. Please help! im in melbourne amd saw your post. thanks Rommie |
Hey mate, where's the car? I can only help with keys, nothing mechanical. Hope I'm not coming across rude but to cover myself i'll want to see something to show that it's actually your car.
