low pressure ac fitting size
I just imported a 2004 x-type wagon and went to charge the ac. I cannot get the product to fit the low pressure port is there a difference in size between the us and can models?
It most likely has the Ford fitting ..it looks similar to the r134a fitting..but is slightly different..make sure you are on the low pressure side fitting..act110a is the snap on adapter..i do not know if or when Canada went to 134a..if you have the Ford fitting it would be original r12 I believe..if someone else knows different please correct me..ac work can be tricky
Thanks, my bad I did not see the low pressure fitting at first and was trying to connect to the high side. Paul |
Sounds like you worked it out. For the benefit of others......
Thank you for this great information. System was out of Freon, filled it last night and it dropped pressure. Used the second can today and it came and seemed to hold for the time being but no cold air, heard the compressor kick in. Will recheck pressure and if necessary check for leaks first. paul |
1 Attachment(s)
Also be aware of TSB No: JTB00183.
bob |
