Nav Screen Problem
I'm having an intermittent problem with the touch screen on my 2002
X-Type and would appreciate any thoughts on what it might be. Maybe 25% of the time, it works perfectly fine. The rest of the time, although the display itself looks fine, when I touch the screen nothing happens - it's just as if it wasn't a touch screen. It seems to work more often when the weather is on the hot side if that's a clue. Once it's working it seems to stay working at least until the ignition is turned off. When it isn't working it sometimes springs to life while driving along - I'll touch the screen and it will be back again. Does anybody know if there's likely to be an easy fix for this? Loose connection maybe? Software problem? Or does the screen need to be replaced? Thanks for any help, Paul |
RE: Nav Screen Problem
Have you tried resetting it? Not sure how....but there is a way to re-boot it....
I haven't hear of any software updats for the 2002 model year... ________ Washington Marijuana Dispensaries |
I don't know how to reboot it. If anybody does I'll certainly give it a go.
You will have to take it to the dealers and they consult their
TSB's the options will include replacing the DVD unit! Don't have a heart attack as the actual solution (worked for me) is that they put the firmware DVD in and leave the ignition switched on for about 20 - 30 minutes, this allows the system to reboot itself and burst into life. Seems a good idea to leave these setup buttons alone unless / until we have supporting documentation regarding their actual usage ! ________ GET I INHALE IOLITE VAPORIZER REVIEW |
