Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   X-Type ( X400 ) (https://www.jaguarforums.com/forum/x-type-x400-14/)
-   -   Oil level dipstick query (https://www.jaguarforums.com/forum/x-type-x400-14/oil-level-dipstick-query-196021/)
Slownot Jan 29, 2018 01:01 PM
Hate to ask this question as I am a mechanic
First jaguar , 2.1 litre, petrol, manual gearbox 2002 x type.
Completely drained engine oil and removed oil filter , fitted new filter and sump plug, using correct specified oil , added 6 litres which i read in the manual to be correct, is only showing minimum on dipstick after leaving overnight.
Is it possible it has the wrong dipstick in it ?
Is there anyway of identifying wether it's the correct dipstick or not ?
Dell Gailey Jan 29, 2018 02:36 PM
As you are a "mechanic", the 6 litres is the full capacity of the oil pan, etc. NOT including the amount used/held in a NEW oil filter. Could be low because of that singular reason. When I drained and replaced mine (2006, 3.0) I used the normal requirements as a baseline, still ended up using more after it "settled in". Never used a drop more since.
Slownot Jan 29, 2018 03:08 PM
Well the manuals say 6 litres for a oil and filter change , that says to me when completely empty of oil and completely refreshing
JBzXJ40 Jan 29, 2018 03:16 PM
Here is NZ I was putting around 6.3L on services. Puts it around middle to upper side of dipstick.
avern1 Jan 29, 2018 03:28 PM
1 Attachment(s)
The Jaguar shop manual states 6.5 liters for capacity or about 6.7 quarts. So you should be reading low right now.
Slownot Jan 29, 2018 03:54 PM
Ok can't understand why literature I've read through all say 6 litres for an oil and filter change , I will recheck tomorrow in case I'm reading it wrong
Dell Gailey Jan 29, 2018 04:35 PM
My manual says 6.1 quarts, yet the Jaguar shop manual says 6.5 so there you are.
© 2026 MH Sub I, LLC dba Internet Brands
