AndrewG |
06-23-2018 11:55 PM |
Quick Question About Trans Fluid Level Check.
So from what I understand you need to get the tranny fluid up to about 95 degrees f. Then get the level check plug off and let it drain till it doesn't anymore, or add fluid till it drains out of the level check plug.
My question is will having the car only raised in the front affect the level plug reading? I have these ramps I drive the car onto and was planning on using those for this of course. However since the car would then be on a grade I'm concerned I'll get an inaccurate reading.
Thanks,
Andrew
