Spark Plug Replacement Tip.
Old Feb 7, 2011 | 12:42 PM
2006XXXType's Avatar
Default Spark Plug Replacement Tip.
So don't replace the factory:
With one like this from pep boys:
Or you run into this:
https://www.jaguarforums.com/forum/showthread.php?t=49548
Old Feb 7, 2011 | 03:52 PM
Thermo's Avatar
Veteran: Navy
XXXType, looking at the plug, can you see what was causing the problem? I would venture to guess that at some point the plug was bounced off the end of the carton, resulting in one of the posts getting bend inward, effectively shorting out the plug, resulting in your dead cylinder. But, I am only going off of a best guess here.
I have used the Bosch +4's on other modern day engines and didn't see anything that would justify their cost.
Old Feb 8, 2011 | 04:07 PM
hlgeorge's Avatar
The NGK Iridium plugs work great! No problems what-so-ever.
Old Feb 8, 2011 | 07:40 PM
Gus's Avatar
Gus
I have been using Bosch+4 in my 99xk8 and I recently replaced them with +2 and the next time I replace them I am going back to the +4. I was using +2 in my 2000 s-type and replaced them with the standard Bosch plug and when I need to change them they will go back to the +2 or +4. I can feel the difference. And that is my .02¢
XJsc-guy
Nov 23, 2015 01:56 PM
Charlene n John
Sep 28, 2015 06:01 AM
Charlene n John
Sep 6, 2015 11:03 AM
KarimPA
Sep 3, 2015 07:32 PM
XJsc-guy
Sep 2, 2015 11:43 AM
