split vacuum elbow pipe to turbo (diesel)HELP
Hi, I own a 2004 2.0Ltr diesel and just noticed the rubber connecting elbow is split which fits on what looks like a vacuum unit on top of the turbo unit. I went to my nearest main dealer and was told only the entire pipe assembly was available to order as a part at around £80, and its not even gold plated!!!
All I need is the little rubber elbow so I wondered if anyone has any suggestions as a I am not paying that. Many thanks, Reggie |
With this forum being based in the US you probably wont get any help from virtually all on here as they never had the diesel engine X Type over there.
You have 2 possibly 3 choices.... Either the dealer or a breaker (like Eurojag in Darlington worlds biggest breaker usually have 400 Jags in at any one time) Another option maybe a Ford one as a lot of the engine is the same as a Mk3 Mondeo...worth trying to find out as probably cheaper than Jag if same part. Good luck |
Thanks for that info, I will try the ford option first.
Regards, Reggie |
