Top speed
Anybody know how fast the 3.0L goes untill the fuel cut off kicks in?? Just wondering.....thought i ask before trying...
________ Wendie 99 |
RE: Top speed
Wow, thanks to all who responded so quickly! Oh wait....nobody responded.....is it because nobody cares or nobody knows?
Well I found out and for your information it's 121 mph! Really sucks to get blown away by a 2.5 Nissan whose governor kicks in at 145! ________ How To Roll Blunts |
RE: Top speed
sorry, i didnt know...where did you find the info?
RE: Top speed
Took it out myself on a long back road.........sucks to be blown away by a nissian that you took off the line up till 110, then he pulls away!
________ ISLAM ADVICE |
RE: Top speed
That's strange... my got my 02 2.5 to 130 mph (thanks for I-44 toolway in OK) and that wasnt the top speed yet.. still had room under the pedal..
RE: Top speed
I think if PCM tune is enabled then say good bye to speed limiter .;)
RE: Top speed
I had mine go over 121;)
RE: Top speed
Got mine to 130 once, but that was a little downhill, every other time it cuts out at about 124mph
RE: Top speed
I've yet to test my car past 130, but it got there rather easy!
RE: Top speed
The S type is a bit different. I think they are set at 135. The X is 121. As of now, there still is nothing out to remove the speed limiter. The The S type has more performance options for removing and updating the ECM, Vers the X type which cost a small fortune and still doesn't remove the limiter...
RE: Top speed
I heard that there was a tune up program for the diesel X Types that disables the speed limiter and give extra 20 HP .Approximately one hour ago, I talked to one of mechanics who prepares racing engines for the teams and official Mossellman dealer told me thathe will get a new PCM program which will be available for Jaguars and other leading car makers in two months .
RE: Top speed
Oh yeah, i forgot about the X type Diesels. Yeah they have a good ECU kit...
RE: Top speed
RE: Top speed
Hey, for some reason I've been getting a lot of double posts too! Tonight I'll be going out to the races and I'll test my top speed!
RE: Top speed
Yeah, I'm not sure what happened with the double post stuff....
but yeah, def let us know what you got for top speed. I'm gonna guess buck 30. |
RE: Top speed
My jag when around a buck 30 as 04 stated but it cut off after that....it did get up there quite effortless and had some more but oh well....don't need to go that fast anyways!
When you guys double post does the screen freeze and than you re-type what you typed??? That is my guess because mine takes forever and I just refresh the screen and paste what I typed if the screen freezes.... |
RE: Top speed
When you went 130, did u still have a couple thousand rmps to spare, cos i know i did, i want to see how much more mph i can get using them
RE: Top speed
When I hit 130 I still had about 1500 rpms to go....IN 4TH GEAR!!!!!!!!! That's what pisses me off! I have more RPMS and ANOTHER WHOLE GEAR!
RE: Top speed
When im in 4th at 125 im little under 6k, so i feel the same pain.
RE: Top speed
Well, last night I ended up going to go watch 28 weeks later...really good by the way...so I didn't go to Towers nor Okeechobee to the races so I couldn't test the top speed. I'll try and do so next weekend!
