Transmission Shifting on 05
Hey guys;
I have a 05 with 51k miles I got last week. I bought it in VA and paid an independent 3rd party to inspect the car and test drive it with special emphasis on the transmision and transfer case noises and performance. The mechanical inspection and test drive came back as great, so I got the car. The transmission seems to shift flawlessly 98 percent of the time, but I have noticed now on two occasions, and only when turning right, if I quickly let my foot of the gas and then accelerate again the car won't exactly jerk, but will have a strange very firm upshift, almost a very light jolt. I have already changed the trans fluid. This could be me being paranoid. I was the same way when I first got my first X type. The car never jerks or hesitates out of a stop. Only happens when turning right Any help appreciated |
Well I just spend one hour this morning trying to car to replicate what I felt when turning right with no luck. I even shut it down and restarted it and tried it in a parking lot. Hopefully I am just overly sensitive
Am guessing you are paranoid. Might be that if you take your foot off the accelerator and then put it back on quickly you are probably just at the right speed with just the right amount of pressure where the transmission is in that sweet spot between gears. Now if it did it all the time that would be a different situation. Might also be the now that the car has a different owner the transmission is " learning" how you drive and is trying to adapt.
Originally Posted by Alfadude
(Post 1707089)
I had to drive about an hour in 5PM 100degree weather traffic to go downtown, and the car definitely is not its
best in very low gear letting of the gas and quickly accelerating again and stop and accelaring again etc etc. I felt a couple of jolts or confusion ,but I think that's just how these transmissions function. I think this is how my 04 was for the most part. I have already gone thru +24 quarts of Castrol multi import ATF. I added Lucas Trans fix on my RIP old X type and the transmission was still working well when it flooded out at 100k+ miles. Hopefully it does the same on this car. i am pondering using Amsoil the next drain and fill, but not sure if it would be worth the cost or if it can mix with all the Castrol ATF in there safely. But maybe in a extreme climate like South Texas Amsoil is worth it. |
