Vehicle inertia switch
Old Mar 5, 2018 | 06:44 AM
jaguar.awd's Avatar
Originally Posted by Dell Gailey
Thank you very much for answer.
It would be excellent if I need to replace nothing, but I should go to official Jaguar service ("dealer"). That is not easy, because the nearest service is in Beograd (Srbija), but I live in Mostar (Bosna i Hercegovina).
Old Mar 5, 2018 | 08:56 AM
jaguar.awd's Avatar
Continue to Thermo
There are same "seals" on all four door windows. Do you know meanings?
Old Mar 5, 2018 | 11:29 AM
Alfadude's Avatar
Originally Posted by jaguar.awd
I have 2004 Jaguar X-type 2.5 classic (driver is on left side).
In november 2016. a motocycle crushed into front right wing. The Jaguar's enigne stoped because inertia switch was activated.
I couldn't move the engine by key immediately. When I found the button near passenger right knee,
I pressed the inertia switch button and after that I could move engine. I replaced wing, and I thought everything is OK.
But, in spring 2017. started problems with P1582 failure. Almost 1 year I drive with "yellow" light on control desk. I did not know how to solve problem, what to do, what to replace. Maybe I need to replace part C2S44918 ?
I do not know, what I should replace after "inertia switch activated"?
How can I solve failure problem "yellow" light icon of engine (P1582)?
The part C2S44918 is easy to buy on eBay, but maybe that part is not damaged. Maybe, there is some contact with wear?
Problem is, in my country there is no official Jaguar dealer, with original Jaguar computer, and nobody can do "hard reset".
I have no any other engine problem but that "yellow" light icon (P1582)
P1582 will not trigger a check engine light or other kind of notification. P1582 is just informational and doesn't indicate a problem. You probably have another code if you have a yellow warning on the dash. Get the car scanned with a different code reader.
Old Mar 5, 2018 | 12:07 PM
jaguar.awd's Avatar
I tried with several code reader, but never in official Jaguar service. All that aplications use in services like Fors, Toyota, Mercedes, Volkswagen, Audi, ...
All indicates only "P1582" and I cannot understand why "yellow" egsists in last 10 months, contantly.
Old Mar 5, 2018 | 12:51 PM
Alfadude's Avatar
What yellow light is on the dash? The engine icon or is it one of the solid color ovals? If it is the oval you might not have a P code. Could be a wheel speed sensor and I believe those are C codes. Maybe teh reader you are using can't read C codes.
Old Mar 5, 2018 | 01:26 PM
jaguar.awd's Avatar
This yellow icon
Old Mar 5, 2018 | 02:43 PM
Alfadude's Avatar
I don't know what to tell you. For thecheck engine light to be on, there has to be an associated code that triggered it. I am not 100% positive, but I believe only P codes will cause the engine icon to light up. P1582 doesn't cause the engine light to come on. There has to be something else that triggers it. Can you hard reset the car by disconnecting only the negative battery cable, then touch the negative to the positive still connected cable. See if that will extinguish the light.
Old Mar 5, 2018 | 02:49 PM
  #28
Thermo's Avatar
Veteran: Navy
jaguar.awd, here is what you are after:
Sekurit Saint Gobain: stands for the Saint Gobain Sekurit corporation that does window glazing security. They put numbers on the glass to help identify vehicles when they are stolen and is associated with the vehicle when it is originally manufactured.
Dot27: Another reference to the Sekurit corporation, but this references back to them being out of Germany
The rest of the numbers from what I can tell are relating to a specific set of glass that is used. I beleive this is more of a part number than an ID number.
Old Mar 5, 2018 | 09:06 PM
jaguar.awd's Avatar
Thanx to Alfadude for post #27. I will try that "hard reset".
Thanx to Thermo for post #28. I replied in post #20 and asked something about "10/03"
Old Mar 5, 2018 | 11:29 PM
  #30
Dell Gailey's Avatar
October of 2003
Old Apr 24, 2020 | 10:08 PM
  #31
Franchie Dutchez Sanchez's Avatar
Default Sam
i think im having thay same issue .when i tried to switch my car over it wont say anything. I was thinking the starter but im goin to try this switch tomorrow.
Old Apr 25, 2020 | 10:54 AM
  #32
Alfadude's Avatar
Unless you have just been in an accident the inertia switch is not your problem If the car was running and now will not turn over first place to start checking is the battery. They can go out without warning.
Wolfy
May 28, 2024 08:06 AM
Rivguy
Nov 13, 2022 02:55 AM
scooternva
19
Oct 27, 2015 02:14 PM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
laserguy
Sep 3, 2015 02:02 PM
