WARNING: Auto Trans Fluid change
Today, I've flushed my tranny three times. First time, I followed JTIS spec, as I didn't know what to expect. Here's what JTIS says:
Lower the vehicle. Remove the automatic transmission fluid charging pipe cap. Use automatic transmission fluid WSS-M2C922-A1 or equivalent meeting Jaguar specification. Fill the automatic transmission with 8 litres of automatic transmission fluid through the automatic transmission fluid charging pipe. Carry out a fluid level check and adjustment. So I did. Added 8 litres of fluid after the drain, ran through the gears until at operating temp, then did fluid check. It spilled out about 4 and a half litres. So actually, what you can drain with the drain plug is about 3 and a half litres, the rest stays in the cooler and torque converter. Next time, I added only 4litres, so that I could drain half a litre via the drain plug, just to know fluid was high enough. Just makes me sorry I threw 4 litres in the trash bin the first time, following JTIS spec. Hope this helps someone! |
8 litres is the dry fill not the drain and fill.
Thanks for confirming my thought...
But JTIS says this on the "draining and refill" page... Just a typo I guess, but wanted to make sure everyone knows. |
Originally Posted by Wannes
(Post 182042)
