X-type fired up once after repair but now won't start at all
The car has been standing six months waiting repair. I finally got round to changing the clutch master cylinder and during this period disconnected the battery to recharge it (not sure if that is relevant or not). On putting everything back together the engine started fine and I let it tick over for a few minutes before turning it off. Now it won't fire at all, only some of the dashboard lights come up (oil light and airbag light) and the red light in the centre console (DSC light?) stays on. The message indicator looks as if it is pulsing but no words come up. The central locking and lights don't work but the electric windows do.
Any ideas? it's a 2008 diesel estate. |
First thing I would check is to make sure the battery is good. If it sat six months maybe it could take a charge enough to start the car once, but if you ony ran it for a couple minutes and shut it off that wouldn't be enough to keep it charged. The load from starting might have taken too much out of it. That would be the place to satrt trouble shooting this, especially considering it was running.
You should also check and clean the battery terminals. Symptoms sound like low voltsge.
Unfortunately it's not that simple. We've tried a couple of batteries, both newish and fully charged as well as checking the terminals but no joy. It's a bit puzzling that the electric windows are working perfectly well, so power is obviously getting to them.
When you turn key to on (not start) does the MIL (little engine icon) remain lit or extinguish?
Hi Dell. That light goes out although the airbag light the oil light and that red light in the centre console stay on.
If the MIL extinguishes, that is a Jaguar indicator that the "immobilizer" is activated.
Originally Posted by acecahuskies
(Post 2094916)
Disclaimer: I am advising according to what I have had experience with. All the times even now,I have a car with the same symptoms. I found out the ECU was the problem. Unfortunately, all the ECUs i have purchased from eBay have all had the same problem, am not sure I am the one with the problem, but I have successfully using SDD swapped and added an instrument cluster from the junk yard and it worked well. I have only one option, to purchase a brand new ECU. But if you can get a place from which you can swap the ECU, it will definitely fire up. By staying solid, and not blink, it means the immobilizer(instrument) has accepted the key, if it hadn't, the light would be blinking |
^^^ uuummmm.....no!
PATS light staying on solid is a fault. Same as M.I.L. extinguishing before starting. |
Originally Posted by Dell Gailey
(Post 2099342)
^^^ uuummmm.....no!
PATS light staying on solid is a fault. Same as M.I.L. extinguishing before starting. On mine, sorry, a customer's after replacing a new ecu kit and test driving it for a couple of days, I woke up to a non start issue. The light remained on solid. Upon running SDD, I found that SDD showed an 'X' for the ECU. When i checked VID blocks,t hey were corrupted. What could you advise about it? |
