X-type loss of drive.
Greetings, at 20 mph I went to change up and there was no drive at all. The manual gear lever waggled about as if I was stirring porridge.
There was no noise or any manifestation of a problem. I just went to move gear lever into 3rd gear and it was missing.. all other gears gorn too. :( The car is a 2004 2litre Diesel 5 speed manual gear car. Has been outstanding up to now. (New tyres and front discs and pads fitted only last week!) Any suggestions please Thanks DaveP. |
Ok, first thought is shift linkage/cable out of alignment. To check this, disconnect, then using a screw driver or some such see if you can manually cycle through gears.
Secondly, the clutch slave cylinder is low/out of fluid or gave up the ghost. Third, the clutch died. |
