ECU mod on the XE R 3.0
Have folks here done any ECU mods. Coming from an Audi S4 there where a number of options. Many folks took advantage of those options. Curious what's up with the?
Originally Posted by Joearch
(Post 1480052)
At this point it would appear a company called Velocity' can tune the base 340 h.p.to the higher spec, something like 380 Lawrence |
Originally Posted by Mulmur
(Post 1480071)
The F type forum has examples or discussions regarding the v6 and tuning.
Originally Posted by Foosh
(Post 1481714)
Yes, Velocity is a well-respected company, and they can flash the OEM V6S tune (380HP) on the 340 V6, which is the XE-R engine. I believe the price now is $1K or under.
CRS |
Originally Posted by CRS 123
(Post 1481841)
Does flashing cause any warranty problems? Also: Does it mess with adaptive dynamics and gearbox mapping? Thanks for any info.
CRS The ECU can be 'read' by Jaguar, for instance, if you blow the engine, even if you remove the tune... this according to the master mechanic at my dealer and he would know, as he has friends that have done tunes and he has been involved. Having said that, he showed me a 5.0 litre engine block a year ago with a hole in it... the engine threw a rod... Jaguar investigated the file and found the engine had been over-revved by at least 1,000 rpm, and worst of all this was with a down shift.. they decided to fix it for the owner anyway as he was a repeat customer. Lawrence. |
