XE ( X760 ) 2015 -
ECU mod on the XE R 3.0
Old Jun 12, 2016 | 03:49 PM
Joearch's Avatar
Default ECU mod on the XE R 3.0
Have folks here done any ECU mods. Coming from an Audi S4 there where a number of options. Many folks took advantage of those options. Curious what's up with the?
Old Jun 12, 2016 | 04:15 PM
Mulmur's Avatar
The F type forum has examples or discussions regarding the v6 and tuning.
At this point it would appear a company called Velocity' can tune the base 340 h.p.to the higher spec, something like 380
Lawrence
Old Jun 15, 2016 | 07:02 AM
Foosh's Avatar
Lawrence
Yes, Velocity is a well-respected company, and they can flash the OEM V6S tune (380HP) on the 340 V6, which is the XE-R engine. I believe the price now is $1K or under.
Old Jun 15, 2016 | 11:56 AM
CRS 123's Avatar
Does flashing cause any warranty problems? Also: Does it mess with adaptive dynamics and gearbox mapping? Thanks for any info.
CRS
Old Jun 15, 2016 | 07:06 PM
Mulmur's Avatar
CRS
Personally, I would assume my warranty is toast for any parts the tune could affect.
The ECU can be 'read' by Jaguar, for instance, if you blow the engine, even if you remove the tune... this according to the master mechanic at my dealer and he would know, as he has friends that have done tunes and he has been involved.
Having said that, he showed me a 5.0 litre engine block a year ago with a hole in it... the engine threw a rod... Jaguar investigated the file and found the engine had been over-revved by at least 1,000 rpm, and worst of all this was with a down shift.. they decided to fix it for the owner anyway as he was a repeat customer.
Lawrence.
AlbBolivar
Sep 1, 2015 04:34 PM
smartobject
Jun 15, 2015 02:25 PM
asaaidi
Oct 28, 2014 03:54 PM
Howie
Jan 22, 2014 05:49 AM
LoveTheGrowl
May 26, 2012 10:22 AM
