Mystery Chime (Yup, I searched)
Afternoon - Hope your collective knowledge can help me from going insane! I have had my car for about a month now. Love everything about it, but its making a noise or chime that I can't identify.
Here's when it occurs - Approximately 3 or 4 minutes into a trip - Does not matter if it was from a cold or warm start - Occurs when my phone is connected via BT or without (I thought it was a phone notification issue so went through turning all that off and no change) It is a two note chime that happens three times in a row. EVERY TIME! A few times has occurred when using right scroll button on the left side of the wheel within first couple of minutes of a trip (next track button), but also occurs if I touch nothing. No dash warning lights or messages appear. Sounds comes through the speaker system, and radio is muted as if on a call or navigation directions were occurring. Once it happens, does not occur again during the trip. Car is a US market car with the Prestige package, InControl (not Pro) and has the Vision Package. After the tone happens and even before all systems are working fine including BT, streaming, XM etc. Trying to have a clue of whether its related to the InControl, or a sensor or something else so i can give the dealership a clue when I try to explain it to them. It's almost like I'm getting a tone saying everything is up and running and at operating temp?? Anyone have a clue? Appreciate your expertise or suggestions on other ways to narrow it down. Last thing I can try is turning off the InControl for a trip and see if it still occurs but not sure that helps narrow it down to that system. Thank you in advance. |
I have a similar car but have not had that happen. The only thing that came to mind was a low tire pressure warning??
Unfortunately not it, but problem seems to have gone away with Android update. Now I can't maintain a BT connection! I would have been happy with the chime coming back!
I had a similar problem with the bt connection to my iPhone. I had kept the iPnone plugged in to one of the USB ports in the console (to keep it fully charged, and for phone access to my contact list) while using the bluetooth for phone calls. The bluetooth kept disconnecting. My service manager suggested that I instead buy a USB plug in the cigarette lighter socket in the console to charge my phone. I no longer have phone access to my contact list, but the bluetooth works flawlessly. |
Yes. That USB port doesn't just charge the phone but it links it to the invontrol. So BT won't work properly at the same time
A cheap usb charger adaptor plugged into the 12V socket is an easy fix |
If you have InControl Touch Pro, it is probably the red light camera / speed camera warning. It can be turned off in the navigation settings.
Originally Posted by Nick Hampton
(Post 2034858)
I had the exact same problem when I first bought mine and put it on a shortlist to ask the dealer about. Then one day I was driving with the nav screen active and saw the chime was a warning about red light cameras. |
Not Signals
Guys - thanks for the responses. Since I don't have Pro, it's not the signal issue. I think it's related to the system booting up and me trying to do something before it's ready. Will test the theory some more. Also, thanks for the reminder about BT issues when plugged into the USB for the incontrol. Seems to be related to iOS which isn't an issue.
NOW, if anyone is having success on still using BT with the non-PRO system after updating a Samsung S9 to Pie, please let me know what you did to the phone to get it to work. I'm getting the 30 seconds connected and then disconnect routine. Have tried several adjustments to the phone with no success. thinking it maybe the version of my InControl. What should be the latest? Thanks |
