What is the difference between dynamic mode and sports mode?
The manual's description is vague about what the modes actually do. It is clear that when both are engaged, the car keeps the engine at high RPM. But what does each individually do?
The Sport mode is only for the transmission. All it does is increase shift points for each gear and hold them for longer, it also will blip the throttle on aggressive downshifts.
The Dynamic mode changes several things. It makes the throttle response sharper, steering heavier and traction control system less obtrusive. |
Thanks, that clarifies things. Some additions questions: So, dynamic mode does not affect the gear shift points in itself? On the other hand dynamic mode+sports mode seem to keep the RPM constantly high (I guess in the turbo range).
On top of the things above, if you have adaptive suspension dynamic usually stiffens it up, and I thought it kept the car in gear longer too. And it makes the dash angry! In cars with active exhaust it opens the baffles to get more of a growl.
Dynamic mode makes everything more aggressive as you can see in the dynamic menu as you can turn each area on/off if you like.
I made my own mode with all dynamic on except steering which I think is a little artificial at times, but if I really want to be sporty I turn them all on.
Originally Posted by BigCat09
(Post 1587793)
My dealer told me that Sport mode is to change the gears manually with the paddle shifter...... well it was some girl they use to explain tech to buyers so I guess she may have no idea what it really is :) (but she did seem informed). If Sport mode is what you explain then how do I go about changing gears with the paddle shifters?
I'm afraid that the girl was wrong about that. You can use the paddle shifters in any mode. To use the paddle shifters, all you need to do is to flick one (up or down) and then they are engaged. They stay on while you are using them, but if you dont use one for maybe a minute it goes back to full auto.
Even using the shifters the car will shift down by itself when you brake. In most modes it will also shift up rather than to redline, but not if you are in track mode from memory, and in that mode the gear number which shows up on the dash should go yellow and then red to warn you that pistons are about to pop through the bonnet. I havent done this in the XE so check it before overrevving the car... |
Thanks for that info :) I would not be doing anything crazy like that anyhow so I think I safe :) the car is fast enough for me in dynamic/sport mode to try anything else.
The paddle shifters can be enabled and disabled in your setup menu too. I think it helps to have them turned to "off" in the "D" setting, and I have them set to Enabled on the "S" dial setting. This way I know I will be in "S" mode whenever I use the Paddles.
If the paddle mode is active in your setup menu for that D or S setting, all you need to do is try pulling one paddle back it should automatically switch to from auto to manual shift mode and show you what gear you're in (front and center of the dials), in order to enable you to make your choice to up or downshift from there. |
Originally Posted by Austin7
(Post 1600493)
If the paddle mode is active in your setup menu for that D or S setting, all you need to do is try pulling one paddle back it should automatically switch to from auto to manual shift mode and show you what gear you're in (front and center of the dials), in order to enable you to make your choice to up or downshift from there. 8 gears with paddles on a car so powerful is another story. Really not necessary. I understand the benefits of gas mileage, but if you haven't already noticed... There's little difference in playing around with 4th-8th. It's hard to tell by ear, throttle response, or seat what gear I am in like a traditional manual. I wish Sport mode code back to D once manual is engaged. Only way I find is to back into normal mode to cancel the paddle... |
(Post 1600521)
Agreed that is wise to disable in D mode. It's a pain the rears if you tap the gear lever by accident in D. Sport mode and the paddles are a pair. I will go into Sport mode and try not use the paddles.
8 gears with paddles on a car so powerful is another story. Really not necessary. I understand the benefits of gas mileage, but if you haven't already noticed... There's little difference in playing around with 4th-8th. It's hard to tell by ear, throttle response, or seat what gear I am in like a traditional manual. I wish Sport mode code back to D once manual is engaged. Only way I find is to back into normal mode to cancel the paddle... I sometimes use the paddles during the overtaking or if I am driving on a hilly terrain (engine braking on downhills). It is not easy to modulate the throttle to achieve kickdown to a correct gear. Also, if you in Sport/Race mode and don't pull any paddles, the car will upshift for you. But if you start using paddles, then it becomes fully manual meaning you have to upshift, the car won't do it for you anymore. |
Originally Posted by Demetre Gvaramia
(Post 1600530)
You might already know this but if you are using the paddles in D mode and want to go back to full auto (instead of temporary S) you can pull either paddle for 1-2 seconds and it goes back to full auto mode.
Don't bring your car to Sudbury Jaguar for service... |
That was the same in your XK, bigfella! All of my Jags have done it since the 08 XF.
I usually pull the "up" paddle, that way you dont get engine braking because it usually changes gear when you first pull. I quite like the paddles with the 6 in the f type - in fact it is miles better than I was expecting because I pretty much thought 8 gears in a sports car is 2 too many, until I drove it. That said, the f type is a lot louder and it is easier to know where the revs are at without looking at the tacho. It is also the 380hp 6, not the 340. |
deleted: wrong thread due to "related threads" at bottom of thread posting.
Dynamic Mode does way more for the cay than Sport mode. In the end, I drove the car in dynamic mode a lot of the time, wakes the car up more. Sport mode is a big nothing IMO. Sport more on Lotus or Aston is like a kick in the ass. Car practically jumps.
I don't feel the steering or the throttle response change as I do in my Corvette..Just trying to get to the bottom of what is actually happening.
Originally Posted by traknut
(Post 2090646)
Dynamic Mode- Improved throttle response, heavier steering, if optioned, stiffer suspension, (exhaust valves open on F-types) No other Jaguar Besides F pace SVR has an active exhaust.
D vs S- you can enable paddles in D through the menu, and they are always enabled in S, either mode can be used without using the paddles. In S it holds the gears longer and has more aggresive downshifts. In D if the paddles are activated it will shift at redline regardless. in S mode using the paddles the car will NOT shift up and bang off the rev limiter. Every single mode will auto downshift to avoid from bogging or stalling when coming to a stop. |
