2011 Jag XF Engine Code P0627
Hello Jag community. needing some help. Im receiving P0627 code (fuel pump circuit open) the car will sometimes not start, and will sometime fall dead while driving. I replaced fuel pump with OEM part April '17. Can anyone tell me what this problem is? Thanks.
If the pump is OK check wiring, fuses, relays etc.
Thanks JagV8, by any chance do you know where fuel pump relay switch is located on this model? Its a 2011 XF Base 5.0L V8
No but I think someone made the workshop manual available if you look.
Did you ever figure your issue out? I seem to having the same issue now. |
Engine code p0627
Did you ever solve the problem? I changed my fuel pump now my engine light on
