XF (X260) 2015 onwards
2011 Jag XF Engine Code P0627
Old Feb 27, 2018 | 09:59 AM
timdmoss's Avatar
Default 2011 Jag XF Engine Code P0627
Hello Jag community. needing some help. Im receiving P0627 code (fuel pump circuit open) the car will sometimes not start, and will sometime fall dead while driving. I replaced fuel pump with OEM part April '17. Can anyone tell me what this problem is? Thanks.
Old Feb 27, 2018 | 12:41 PM
JagV8's Avatar
If the pump is OK check wiring, fuses, relays etc.
Old Feb 27, 2018 | 02:30 PM
timdmoss's Avatar
Thanks JagV8, by any chance do you know where fuel pump relay switch is located on this model? Its a 2011 XF Base 5.0L V8
Old Feb 27, 2018 | 04:44 PM
JagV8's Avatar
No but I think someone made the workshop manual available if you look.
Old Dec 10, 2018 | 04:30 PM
Mattsikes's Avatar
Did you ever figure your issue out? I seem to having the same issue now.
Old Oct 18, 2019 | 09:36 AM
Cojag's Avatar
Default Engine code p0627
Did you ever solve the problem? I changed my fuel pump now my engine light on
Don B
General Tech Help
17
Aug 8, 2017 09:11 AM
Miss Charlee
Oct 5, 2016 07:03 PM
Don B
General Tech Help
Nov 9, 2015 12:59 PM
Nov 8, 2005 02:14 PM
