XF (X260) 2015 onwards
2013 Jaguar XF - turning over but not starting
Old Oct 18, 2019 | 12:56 PM
Nik Burkhardt's Avatar
Default 2013 Jaguar XF - turning over but not starting
Hey everyone, I am new to the Jaguar forums. I have a question about an issue that just happened a couple days ago. I am not a mechanic at all, but love working on my cars, and over the last couple decades have increased my skills, my tools and my knowledge base, so I am hoping that with my current issue, I can tackle on my own. However, I am also not too proud to get it to the dealer when I am in over my head. My goal for this post is two fold, I hope someone has had a similar situation and might know a possible solution. Or I am hoping that what I describe has a post that someone can reference and I can check out solutions there.
I have a 2013 XF (2.0 4 cylinder turbo). I bought it last year. It currently has 48,000 miles on it and has been a perfect car (other than passenger side door that wont latch randomly when it is frigid cold lol ... not the issue of the post though). Two days ago, I noticed a slight delay when I started, with a very quick clicking sound, then it started fine and nothing was wrong the rest of the day. Yesterday everything was also fine the first half of the day. I drove home for lunch, but when I was leaving to go back to the office, it wouldn't start. It would turn over, but not fire up. My first thought was spark plugs, but they seemed fine (I did not pull and do a test fire, but they were not gunked up). I had plenty of power, and it turned over just fine, so battery I ruled out. My coil pack did have a little corrosion on the 3rd coil, where it connects to the spark plug, but not an alarming amount. Below are codes that I got from my OBD II reader. My thoughts are fuel, maybe injectors, pump or filter as I have read that there have been issues with each of these for people. So, any advice from the more experienced? I loathe taking it to the dealer from being taken advantage of when I was younger. I appreciate any suggestions.
Old Oct 18, 2019 | 05:51 PM
Fraser Mitchell's Avatar
It is known that a faulty camshaft position indicator can prevent an engine starting. This goes back many years when distributors ceased to be used. Of course the indicator itself may not be faulty, just its wiring connection, but you only really find out when you take the thing off. Funnily enough the engine can run OK with a faulty camshaft indicator.
Jarad Margiasso
Aug 27, 2023 09:40 PM
rsims
Oct 13, 2016 10:59 AM
nickxj6
Jan 26, 2016 06:23 PM
dwiniarz
XJ40 ( XJ81 )
17
Mar 28, 2013 11:14 PM
srteague
Oct 28, 2012 09:48 AM
