2017 XF Steering column adjustment failure
Old Nov 25, 2018 | 10:48 AM
Brad Colby's Avatar
Default 2017 XF Steering column adjustment failure
Hello all!
For no apparent reason at all the adjustable mechanism on my steering wheel appears to have failed. Since it doesn’t move with the driver presets I am assuming that it is a motor failure problem but the fact that it doesn’t move up down or in and out leads me to believe that it’s possibly a fuse somewhere? However I can’t find on any forum or anywhere on the web where the fuse for those motors is located.
Any help is appreciated!!
Old Nov 26, 2018 | 12:51 AM
Swimref's Avatar
Originally Posted by Brad Colby
Hello all!
A 2017 is not an X-250 and you are in the wrong forum. Also, is the car not under factory warranty? If so, don't mess around and let the dealer fix it.
Old Apr 18, 2023 | 04:25 PM
Gicu170587's Avatar
Default Xf steering ajustment problems
Hello all!
hi, I have the same problem and cant find anywhere info. What was the problem?
here I go again
May 11, 2015 04:56 PM
Paul792
Jun 1, 2014 11:21 PM
jaguar99plas
Jun 25, 2012 03:38 PM
drk1074
Feb 21, 2011 11:24 AM
ebuzz22
Nov 24, 2010 09:45 AM
