auxiliary "key" position
The one frustration I have with the keyless ignition is that if I - for example- leave the sunroof open after turning the car off, I then have to restart the car to close the sunroof or operate the windows.
In a car with a key, I would simply turn the key to the auxiliary position and operate windows etc. Is there an equivalent procedure with the XF (mines a 2011 if it makes any difference)? Can you operate windows/sunroof witht he engine off? thanks, ken |
just press the start button without foot on the brake....same as aux key position
Thanks!
My Canadian spec XF also has global close/open. To open or close all windows and sunroof (or any that are open or closed as the case may be) with ignition off simply press and hold the lock button in the car or on the remote until all windows and sunroof are closed, or the unlock button to open. Also works with ignition on or engine running.
Very nice feature on a very hot day to global open all windows and the sunroof as you approach the car, then drive off and global close all as the AC turns cool enough. |
Originally Posted by jagular
(Post 401173)
Originally Posted by Need4Spd
(Post 401260)
US cars have this, too. It's buried in the setup menus somewhere, as I stumbled across it one day. Default is non-enabled. Find it and enable it. I think there are choices to separately turn on global open and turn on global close. I turned on only global close on mine. I was worried a stray signal might tell my car to open itself up...when it's raining.
Originally Posted by CP1
(Post 403642)
And exactly what is this "raining" of which you speak?????
Maybe it works like Murphy's Law. If you program your car so there's a risk that you come back to it and all the windows are down and the roof is open, and it does that, it will rain! |
(Post 401260)
(Post 403642)
Is the closing of the windows with just the smart key accessible with a 2009 XF? Please say yes because this feature is a must!
