Diesel Particulate filter
Old Mar 23, 2015 | 02:39 PM
sambella's Avatar
Default Diesel Particulate filter
Hi guys just getting used to my 58 plate 2.7 XF and going well.
I realise that the DPF does generate quite a bit of heat but actually how much heat is present under the floor of the motor.
I did about 20 miles or so today and when parking up on the drive there seemed to be a smell of burning paint coming from the underside and I assumed this to be the heat from the filter.
The sort of smell you would get after a new exhaust had been fitted.
Just to put my mind at rest is this a common feature or not?
Had nothing come up on the dash with regard to regen so thinking this must be ok or not.
Can you assist.
Pete
Old Mar 23, 2015 | 03:53 PM
OzXFR's Avatar
Yes, when a DPF regen happens you get a smell a bit like burning rubber, this is quite normal.
Delta66
Oct 4, 2015 05:40 PM
redxk8
Oct 4, 2015 08:28 AM
Jaguar Forums Editor
Jaguar Press release
Sep 30, 2015 03:08 PM
Malihide
Sep 29, 2015 03:21 PM
