Oil Leak
Hey guys recently ran into the trouble of an oil spot under m 2010 Jaguar XF Supercharged. Concerned me decided to see if I could located the leak but couldn't see much from the under the hood. I then proceed to put my car on ramps a lift one side and see if could find anything. As far I was able to tell the leak was coming from the passenger side of the engine but couldn't tell from exactly where. I took it to a local shop and had it inspected but the guy told me there was a leak but he had no luck finding where it was originating from. As anyone encounter a problem like this or similar so I can try to fix the problem. The dealership currently has a 1 month waiting list for appointment so I'm trying to solve this before I spend hundreds for something that might be very simple.
You first need to work out if it is engine oil or transmission fluid or maybe even power steering fluid. I assume it is not coolant as you would know the difference between coolant and oil. The first thing to do is to put some butcher's paper or similar under the car where you park it and inspect (look, feel, smell, even taste!) any drips which show up. Then, once you have (hopefully!) identified what type of fluid is leaking, you're best bet is to remove the plastic under tray and thoroughly clean the underside of the engine and gearbox, drive it for 50 miles or so (with the under tray off) then have another look underneath for signs of fresh leakage.
My car did a similar thing last summer: I got home after a long drive and found a small puddle under the front right of the car the next morning (oil was ~1L down). Topped it up and have kept a close eye on the oil level since - nothing spotted so far (level's remained fine).
Yes, my 2010 developed some seepage, wound up re sealing the lower oil pan as part of my 100k mj XFR service.
It's definitely a oil leak. It was ok for a little while but today when I checked the oil level I was at 1/4 of max. Haven't had time recently to go under and see what the issue might be. Any ideas what I can do to it. It only has 50000 miles on it so it's a bit concerning to see a oil leak.
Not much posted on here on oil leaks over the years. They seem to be v reliable on that. (Lots on coolant leaks!)
So I don't think there is a 'typical' place to look here. Unfortunately you're going to need to go back to diagnostics. Remove drip tray, find the leak and trace it up Sounds like it's losing a fair bit so should be easier to find... |
Agreed - the only way you'll resolve this is by getting underneath. Prime suspects are:
I just hit 50k and had an oil leak. Dealer said the oil filter cover housing was leaking and reseated it. (Maybe there's a gasket on this?). He blamed my Indy. Showed be some tool scratches on the housing said they aren't using the right tool.... oil leak gone.
Originally Posted by EricinNH
(Post 2036105)
