Please help! Tire pressure sensor
Old Jul 10, 2014 | 04:50 PM
Xf_boy's Avatar
Default Please help! Tire pressure sensor
I went to the tire shop today to change my tires. I got new ones on them but before that the mechanic was trying to take off the cap where the air is pumped through. This did not work as the cap had ceased which ended in the threads breaking off with the cap on it. So tire pressure sensor is broken and I was wondering If I can just put a cheap after market tire pressure sensor on? Please tell me where I can find one and for cheap! thank you very much! 2010 jaguar xf 5.0 v8 tire pressure sensor (315mHZ)
Old Jul 10, 2014 | 05:49 PM
Welcome to the forum Xf_boy,
I've added some detail to your thread title to draw the attention of members with knowledge of TPS.
Old Jul 11, 2014 | 09:48 AM
nasa25's Avatar
Grab one from rock auto for around $40-50.
Old Jul 11, 2014 | 12:30 PM
lotusespritse's Avatar
Are the sensors programmed to the car?
I ask because I want to swap wheels between my 2 XF's.
Old Jul 11, 2014 | 06:17 PM
jaguny's Avatar
When I bought my aftermarket wheels, I bought new TPMS for $50 each from getyourwheels.com. My local tire shop installed and programmed them.
I thought RockAuto is a forum sponsor but they are not in the vendor directory. They are others there they may carry TPMS.
Old Jul 13, 2014 | 10:34 AM
jagular's Avatar
Probably metal valve caps have been used. Not permitted by Jaguar.
Replacement TPMS are brand specific and don't buy cheap ones they'll drive you crazy with faults. Jaguar installs a new style of TMPS which is higher quality and stronger.
Also, make sure your installer knows how to install these properly, they take very low torque and if over torqued they can leak or fail completely.
NEVER fit metal valve caps, always use plastic.
johndahlheimer
Sep 16, 2015 05:44 PM
Armor6
Sep 14, 2015 07:56 PM
KarimPA
Sep 12, 2015 08:15 AM
Armor6
Sep 10, 2015 12:08 PM
fingers
Sep 8, 2015 03:54 PM
