Programming Window
I learned a trick. I took my 2011 XF Premium in to the dealer for them to re-enable the Voice Command. After I got it back I noticed that the one press closure option for the windows no longer worked. I called the dealer and they gave me the programming instructions to re-enable this option.
1. With the Window half open close the window—continue to hold button for a couple of seconds after the windows closes.
2. Release the button and then again hold in the closed position for three seconds.
3. Then roll the window half way down and release.
4. Now open the window completely when the window is completely open continue to hold the button for a couple of seconds.
5. Release the button and then again hold in the open position for three seconds.
This method worked. I did have to perform it individually for both for each front window and once for the both back windows—all from the driver’s control.
philwarner
28
Jul 11, 2017 10:21 AM
blackenedindustries
Sep 30, 2015 10:17 AM
