Xj8 1998 passenger side mirror does not work
Old Nov 20, 2013 | 05:36 AM
Harroche's Avatar
Default Xj8 1998 passenger side mirror does not work
Hello everyone
Can someone help ?
My passenger side mirror does not work
I am able to adjust the driver side but not the passenger side
Is the problem with the driver control or the mirror
Can someone tell me how to check
Old Nov 20, 2013 | 05:47 AM
Haroche,
I've moved your question from General Tech Help to X308 forum. Members here with the same model will be able to help.
Old Nov 20, 2013 | 06:53 AM
Harroche's Avatar
Thanks for your support
Old Nov 21, 2013 | 05:55 AM
Harroche's Avatar
Am I the only one with this problem?
Old Nov 21, 2013 | 06:16 AM
I very much doubt it!
Do you have Powerfold or standard door mirrors?
Old Nov 21, 2013 | 10:52 PM
Harroche's Avatar
Standard mirror
Old Nov 22, 2013 | 12:20 AM
xjay8's Avatar
Originally Posted by Harroche
Standard mirror
As the mirror motors are exposed to the elments....that's where i would look first.
A simple job to remove mirror glass.....just press on inside edge with thumb and lever outside edge with other hand until it 'pops' from it's mounting.
If heated, remove conector and place the mirror down.
The drive motors for vertical and horizontal movement will be seen.
Have a can of elecronic spray cleaner/lubricant hand and give the motors a good spray....injecting some intp the mechanism.
Also look to see that wiring is clean and secure.
While mirror is off, check the movements.
It may pay to spray some lube in the arm rest switch as well as the forward mirror controlbutton (round one)
Still no joy, you will have to dig deeper to expose connetors.
Old Nov 22, 2013 | 07:16 AM
Harroche's Avatar
Ok thanks I will try it.
Can it be the control module?
Is it easy to remove and open?
Old Nov 24, 2013 | 04:56 AM
xjay8's Avatar
I doubt it.
It's usually peripheral problems that cause these faults.
These cars are different to early models as these have 'multiplex' wiring
and are far superior to earlier set ups.
Problems are usually down to fuse, relays or wiring connectors, followed by the motors themselves and lastly possibly BCM.
Old Nov 25, 2013 | 05:50 AM
Harroche's Avatar
Ok thanks I am out of the country this week but next week I will look into it.
Again thanks for your help
Old Dec 4, 2013 | 09:52 AM
Harroche's Avatar
I brought the car to a glass specialist and an electrical expert. He found that the passenger front door module LNC2120AE/XXX is not working properly.So I ordered a new one on Ebay.
When he re-installed it my electrical window stopped to work from the driver console as well as now both side mirrors are not working.
Finally when I got to the gaz station I could not open the gaz tank door.
Are this all inter connected are just more problems?
Can someone help?
Old Jan 13, 2014 | 12:24 PM
Harroche's Avatar
I did a hard reset and everything is back to normal but the passenger mirror still does not move.
I replaced the passenger mirror assembly. No change
I replaced the driver door module . No change
I then replace the pasenger module . Still nothing.
My last option is to replace the door switch module .
Old Feb 17, 2014 | 12:54 PM
Harroche's Avatar
I finally open the door module and cleaned the inside.
The mirror works now.
I wished I started with this.
Hope this helps others
Old Sep 23, 2018 | 03:38 PM
lilfreddie's Avatar
What door module did you clean?
Guernz
Jan 17, 2016 12:22 PM
91xjscoupe
Sep 1, 2015 12:01 PM
frankc
Sep 1, 2015 04:41 AM
daro31
Aug 27, 2015 09:26 AM
divingmom
Aug 25, 2015 07:54 PM
