2011 Jaguar XJ Supercharged Cluster/Dash turned black
Hello. Im new in this forum. Tried to search some posts and info but like I see it's not common problem. So without any previous issues my dashboard cluster turned into black. Car starts.Everything works but cluster stays black.
Thanks for help |
NESPO, sounds like you have a blown fuse that powers the instrument cluster. I would look in your owners manual for which fuse powers the instrument cluster and then replace that. Could be something that simple. Otherwise, you are most likely looking at trip to a service place to have them connect up a computer and force the instrument cluster to do a diagnostic on itself which will force it to light up all the LEDs as part of the test.
Originally Posted by Thermo
(Post 2094451)
NESPO, check fuse F61 in he central junction box. That is the one that powers the instrument cluster.
Just to make sure that I am understanding what you are saying. You can see the radio just fine. If you turn on the dash lights, they will light up except for the screen just above the steering wheel. Correct? I am looking at the electrical diagrams and making sure that I am going after the correct problem. |
(Post 2094552)
