Can our console screens play movies? I put in a DVD once and it wouldn't read it.
Originally Posted by JagGate
(Post 1838102)
https://cimg3.ibsrv.net/gimg/www.jag...25478f7f2a.jpg Select the My Video option, then hit the "+" button. Next select DVD. If you've already done that, then you have to ensure that the disc that you're attempting to play is the correct region setting. If you're in the US, I believe we're Region 1. Other regions won't play. I hope this helps. |
Originally Posted by ABrice
(Post 1838249)
Yes it does. You have to ensure that you select the correct mode.
(Post 1838249)
In addition the DVD will not play on the front screen is the car is moving.
Compatibility
Hi would this work on 2011 xj regards g
Originally Posted by scotsgeeza
(Post 2178241)
The unit in the pictures at the start of this thread is an "AW93" which is for model year 2010. It is my understanding that 2010-2013 units are interoperable. |
Info
Do u mean I shud look for aw93 regards g
(Post 2178271)
(Post 2178271)
Confirming
Just to confirm the module with 500 written on it regards g
Vim
Cheers found firm from Portugal on eBay I take it that’s same people u got urs from g
(Post 2178409)
Help
Thanks everyone for ur help gonna go down the module route when I’m back in the black after Xmas much appreciated g
Arrgh
Just been onto people in Portugal they say it won’t work on 2011 xj so I’m at a loss of what to do
Video in motion
Do you know if this will work on a 2011 xf?
Info
Hi mate not sure just send them a message n they’ll get back to you regards g
That’s surprising. The description in the listing says that it’s compatible with the 2011 XJ. I’m willing to bet that it will work. There’s not much of an internal change in the nav units between the 2011 and 2013...if any change at all. I have a 2013 XJ, and the device works perfectly fine. I bet that it’ll still work. Just my two cents brother.
:icon_wub: Yeah bit gutted thought we’d narrowed down solution
H20Boy's original thread shows pictures of the device he had being installed on a 2010/11. (AW93). Therefore if the device is the same as that used by H20Boy, it will work on a MY2011. As far as anyone can tell, the interfaces of the BW93 (2011/12) and CW93 (2012/3) are identical to the AW93, so if the device works on a CW93 it will almost certainly work on an AW93 (... or a BW93, if you have one of those - as you may). The issue may be that MY 2013 part way through Jaguar changed to DW93 (as I understand it) and the DW93 is not 100% compatible with the AW93. ABrice: is yours a CW93 or a DW93? (did you look?)
