I have purchased a new to me 2004 Jag XJR and need to change the wheels and tires up. Looking at a staggered set of rims from a 2011 Jag XJL.
Specs are : front 5x108 , 19 x 9J , ET 49 , bore 63.4 mm possible tire size = 245/45 ZR 19
rear 5x108 , 19 x 10J ET 46, bore 63.4 mm possible tire size = 275/40 ZR 19
Has anyone mounted this combination and are all your clearances okay ?
There are threads on the max width possible on the rear of X350.
From memory it's indeed around 275. Make a search.
Also something to consider is the overall balance of the car with staggered wheels, the X350 suspensions and geometry were designed for equal wheels front and rear.
A very good point ....Thank you ! I'm pretty much decided against a staggered set after some additional research !
