2005 XJ8L cylinder firing diagram
I would appreciate any help in determining cylinder #7 so I can install a new coil pack. The error codes seem to indicate a misfire on that cylinder.
See post #2 here: https://www.jaguarforums.com/forum/x...j8-4-2l-75948/
Cylinder 7 is the rear-most cylinder on the right side bank . |
According to the Training Guide:
"The engine cylinders are numbered 1,3,5,7 on the right hand bank and 2,4,6,8 on the left hand bank. The cylinders are numbered using the driveplate as a datum point, number one cylinder being the furthest away from the driveplate and number two cylinder the next furthest away from the driveplate and so on ....." So that makes #7 at the back on the LEFT when viewing from the front of the car. |
Thank you both for your help.
Newt |
Replaced the coil pack and the problem was solved. The P2097 code persisted for about 50 miles, but after clearing it again - it stayed off as the excess fuel was burned out of the catalytic converter.
