2005 XJ8L cylinder firing diagram
Old Sep 27, 2013 | 05:33 AM
NDW's Avatar
NDW
Default 2005 XJ8L cylinder firing diagram
I would appreciate any help in determining cylinder #7 so I can install a new coil pack. The error codes seem to indicate a misfire on that cylinder.
Old Sep 27, 2013 | 06:26 AM
mhamilton's Avatar
See post #2 here: https://www.jaguarforums.com/forum/x...j8-4-2l-75948/
Cylinder 7 is the rear-most cylinder on the right side bank .
Old Sep 27, 2013 | 07:08 AM
Partick the Cat's Avatar
According to the Training Guide:
"The engine cylinders are numbered 1,3,5,7 on the right hand bank and 2,4,6,8 on the
left hand bank. The cylinders are numbered using the driveplate as a datum point,
number one cylinder being the furthest away from the driveplate and number two
cylinder the next furthest away from the driveplate and so on ....."
So that makes #7 at the back on the LEFT when viewing from the front of the car.
Old Sep 27, 2013 | 02:52 PM
NDW's Avatar
NDW
Thank you both for your help.
Newt
Old Sep 30, 2013 | 07:37 AM
NDW's Avatar
NDW
Replaced the coil pack and the problem was solved. The P2097 code persisted for about 50 miles, but after clearing it again - it stayed off as the excess fuel was burned out of the catalytic converter.
duecedriver
Dec 25, 2015 11:47 AM
KarimPA
Sep 27, 2015 08:46 AM
KarimPA
Sep 12, 2015 08:15 AM
KarimPA
Sep 3, 2015 07:32 PM
Bowman
Sep 3, 2015 03:17 PM
