Miss fire on 1, 4, and 6
Old Sep 3, 2015 | 11:45 AM
Bowman's Avatar
Default Miss fire on 1, 4, and 6
I recently rebuilt my 4.0 v8 in my xk8 due to the secondary chain and tensioner failing. I thought maybe water in the gas was causing a rough idle but I drained some into a mason jar. It fires up but I'm getting a rough idle and codes p0351, p0354, and p0356. I've tried both swapping the coils and spark plugs from good cylinders to bad and I get no change in codes. I'm at a loss for why these cylinders are not getting spark. Any ideas on what to do to diagnose this issue?
Old Sep 3, 2015 | 12:12 PM
Jandreu's Avatar
go here and download the workshop manual for your MY, listed as the JTIS.
https://www.jaguarforums.com/forum/x...ts-data-29800/
In the JTIS under Powerttain - Engine - Engine Ignition there's a complete list of troubleshooting procedures for your issue.
Old Sep 3, 2015 | 12:27 PM
RJ237's Avatar
What year and how many miles?
Old Sep 3, 2015 | 12:42 PM
DaveInVA's Avatar
If its a 97 with an ECU part number ending in -AK then there is a good chance its the ECU doing it.
Dave
Old Sep 3, 2015 | 01:10 PM
Bowman's Avatar
RJ, It is a 99 XK8 with 45k miles. Dave, I'm not positive the VIN but I will look into that. I'm guess that might be a common issue with the ECU?
Thank you Janreu, I'll have to get the JTIS all setup.
Old Sep 3, 2015 | 02:03 PM
RJ237's Avatar
I don't think there have been many 98 ECU failures, but the misfire on both banks is a symptom often reported. The ECU number is on the VCATS tag near the spare tire.
Old Sep 3, 2015 | 03:17 PM
DaveInVA's Avatar
Another symptom of a bad ECU that seems to happen with the 2 bank misfires is the CC not working. No red light when button is pushed.
Dave
hoodun
Oct 6, 2015 08:34 PM
millertic
Sep 30, 2015 08:11 PM
hoodun
Sep 28, 2015 01:08 AM
