adjust low beam and the high whent up :( HELP!!!
Old Nov 22, 2014 | 11:51 AM
javigo1971's Avatar
Default adjust low beam and the high whent up :( HELP!!!
Hi guys i just replace a passenger side low beam bulb H7 , and adjusted the light cause it was to low couldnt see anything when driving so when to adjust infront of the wall everything when fine untill i turn on the high beam and baaammm/!! they whent to the sky lol... they aim high... so you guys think i installed the bulb in the wrong way or what? or there's another adjustment separetly for the high beam? thanks!!!
when installed the bulb did sit kind of like in 60 or 65 degree it didnt felt right so i left it like that i think it should fit straight 90 degree i guess dont know for sure...thanks any help wellcome...
Old Nov 22, 2014 | 02:24 PM
Fraser Mitchell's Avatar
Did you adjust it with the engine running ? The air system controls headlight levelling, so if you made a manual adjustment without this, then it is highly likely to have caused your problem. On my car, if I start in the dark, the headlights level up when I start the car. If yours are already pointing up, the air suspension will cause them to level-up even more.
Old Nov 22, 2014 | 05:33 PM
javigo1971's Avatar
Default thanks Frasiel but i have the converssion
I m sorry but i forgot to tell that i have coil over conversion ;( my bet!
Wolfy
May 28, 2024 08:06 AM
afterburner1
Dec 16, 2015 12:12 AM
redrover41
23
Sep 25, 2015 01:33 PM
avern1
Sep 8, 2015 06:25 PM
laserguy
Sep 3, 2015 02:02 PM
