Any reason for no signal from Lambda O2 sensors?
'08 n/a X358, 80k miles. I think my old scanner is just not up to the job and so I am about to replace it. Specifically right now, it just shows zero signals from any of the O2 sensors. A visual inspection shows them all to be in place and plugged in. I can't believe I would actually have a problem not reading ANY of them. It must be the reader, right? I have no O2 sensor CEL codes (although I'm fighting bad MAF/running rich in both banks codes).
Is there any chance that points to a different, real problem, or should I just go out and buy a newer scanner? Many thanks! |
A Jaguar specific reader is a must, to read many Jaguar codes.
Most any scanner should read the O2 sensors, they are needed for emissions |
Originally Posted by Wingrider
(Post 2499295)
Originally Posted by jeremy_watson
(Post 2499889)
Any scanner you recommend?
https://www.jaguarforums.com/forum/g...-%2A%2A-33347/ Another dedicated to the 'factory' SDD (Symptom Driven Diagnostics): https://www.jaguarforums.com/forum/g...d-truth-32683/ Graham |
