Any reason for no signal from Lambda O2 sensors?
'08 n/a X358, 80k miles. I think my old scanner is just not up to the job and so I am about to replace it. Specifically right now, it just shows zero signals from any of the O2 sensors. A visual inspection shows them all to be in place and plugged in. I can't believe I would actually have a problem not reading ANY of them. It must be the reader, right? I have no O2 sensor CEL codes (although I'm fighting bad MAF/running rich in both banks codes).
Is there any chance that points to a different, real problem, or should I just go out and buy a newer scanner?
Many thanks!
Many thanks!
See the FAQ's ('stickies') at the top of General Tech Help forum for extensive discussion on code readers and scan tools.
https://www.jaguarforums.com/forum/g...-%2A%2A-33347/
Another dedicated to the 'factory' SDD (Symptom Driven Diagnostics):
https://www.jaguarforums.com/forum/g...d-truth-32683/
sutherland
03-18-2014 09:51 AM
omcstan
22
04-24-2013 08:25 PM
