Air suspension again,,
Good day, this is a new one for me. I was investigating a front end rattle, lifted the left front, just enough to get the wheel off, heard the usual air escape as I jacked.
Looked around, noted that the front pads do not have anti-rattle clips and pads can be moved around in the caliper with ease.
All is good, lower the car and what the heck, I made a low rider?
Not the first time I have poped off the front wheels but this time car is down and will not come back up. Air compressor work, can jumper relay #1 3-5 and the compressor runs, fuses look Okay, tried a hard start - battery off and pos to neg cables touched to drain cap's. Cracked the air fittings at each front shock - still some residual pressure.
Advice?
Advice?
Advice?
Advice?
philwarner
25
06-26-2021 05:43 AM
scooternva
19
10-27-2015 02:14 PM
Guy-Pierre Boucher
09-16-2015 05:55 PM
Andrew Fanshawe
09-14-2015 07:40 PM
2004, air, compressor, front, indication, jaguar, low, relay, shock, suspension, vdp, vehicle, xj, xj8, xjr
