### FREE PRIZE DRAW – Stage 1 Air Intake Tube Kit ### (X350)
3 Attachment(s)
This is a FREE PRIZE DRAW for CALDOOFY’s well known STR/X350 Stage 1 Air Intake Tube Kit
Many of you will know of our forum member "Caldoofy" (John), who has developed this superb upgrade for the 4.2 litre V8 Supercharged model. The advantages of these tubes are well documented. The standard plastic intake tube has restrictions and a design that cancels the induction noise out. Consequently the efficiency of the tube is compromised. Similar to gas flowing a cylinder head, the smoother and increased flow of the Stage 1 Air Intake Tube allows the engine to breathe more easily and in doing so, creates power. The major difference between Caldoofy’s Tube and the normal ones is that you don't need to cut the oil breather hose or even replace it! This custom made 80mm tube will accept the Jaguar push-on fitting, reducing the need to chop yours and allowing you to return to stock easily and without damage. John has very kindly agreed to donate the "Stage 1 Air Intake Tube Kit" MRP £105 ( approximately $167 US / $180 AU ) to one lucky member. The Prize consists of: 1 x Stage 1 Air Intake Tube 2 x Silicon Joiners (in black with polished finish) 4 x Stainless Jubilee (worm drive) Clips 1 x Fitting instructions Postage & Packing included to a UK address or at cost if the winner is outside the UK. To enter the FREE PRIZE DRAW, simply follow this link https://www.jaguarforums.com/forum/s...be-kit-102618/ to the S-Type forum and add your Member Name to the thread. NOTE: All STR / X350 (4.2 V8 Supercharged) member owners WORLDWIDE are eligible for entry. Prizes can be shipped Worldwide via International Priority mail. The winner however, is responsible for any local custom fees, duties and or taxes. Jaguar Forums would like to thank John ( Caldoofy ) once again for his generosity shown to the memberbase. _________________ Good Luck to everyone. Graham |
The draw is now open.
Graham |
https://www.jaguarforums.com/forum/a...ine=1379010210
Thanks to Caldoofy and to Graham......... Good luck to ALL... |
2 Attachment(s)
BUMP
If you have an X350 4.2 Supercharged - don't miss out on a chance to win this great upgrade. Attachment 54687 Follow the link in post #1 to the S-Type forum and add your name to the draw. Graham |
It's the start of:
https://www.jaguarforums.com/forum/a...ine=1379287565 Please remember, the Air Intake Tube Kit is only for 4.2 V8 Supercharged engines. Graham |
1 Attachment(s)
https://www.jaguarforums.com/forum/a...ine=1379373131BEGINS
If you have an X350 Supercharged, head over to https://www.jaguarforums.com/forum/s...be-kit-102618/ and enter your User Name in the FREE PRIZE DRAW. Graham |
Already it's the start of .......
https://www.jaguarforums.com/forum/a...ine=1379461845 Don't miss out. Get your name down. |
1 Attachment(s)
It's on to
https://www.jaguarforums.com/forum/a...ine=1379545601 Numbers are building up. Are you on the list yet? Graham |
Today is
https://www.jaguarforums.com/forum/a...ine=1379633040 Head over to S-Type forum and add your name to the list Graham |
On to
https://www.jaguarforums.com/forum/a...ine=1379718885 Don't miss out on your chance in the Draw. Graham |
6 Attachment(s)
Don't miss out on this superb upgrade for your X350 4.2 V8 Supercharged.
Attachment 55397 Manufactured in round 3 inch T304 stainless pipe with a polished finish, it increases power output and looks so much neater than the stock Inlet. A turned stainless fitting TIG is welded to the tube for connection of the Jaguar oil breather hose: Attachment 55398 The standard oil breather fits directly to the Inlet with no modifications required: Attachment 55399 This photo shows blue connectors but the kit now comes with polished black silicone joiners and stainless steel Jubilee (worm drive) Clips. Full fitting instructions are included and installation should take no longer then 15-20 minutes. For full details see Caldoofy's thread: https://www.jaguarforums.com/forum/s...it-strs-83960/ Graham |
It's already Day
https://www.jaguarforums.com/forum/a...ine=1379805759 There's one name on the Participant List still in RED. Is it yours? Graham |
The Days have ticked by
https://www.jaguarforums.com/forum/a...t-weekdays-jpg The clock is running down. It's https://www.jaguarforums.com/forum/a...ine=1379892111 Don't miss your chance to win this superb PRIZE https://www.jaguarforums.com/forum/a...t-intake_1-jpg Graham |
This is it:
https://www.jaguarforums.com/forum/a...ine=1379977757 That means there's only https://www.jaguarforums.com/forum/a...ine=1379977757 left to get your name down on the Participant List. Graham |
Less than 4 hours to go to enter your name in the FREE PRIZE DRAW!
https://www.jaguarforums.com/forum/a...ine=1380049520 |
https://www.jaguarforums.com/forum/a...ine=1380053738
But there's still time to get your name on the Participant List. Graham |
When the counter in my Sig reaches 00:00 - the draw will be closed......
https://www.jaguarforums.com/forum/a...ine=1380060682 Graham |
The Promotion is now CLOSED. The winner will be notified by forum PM or eMail no later than 3 days after the close. Jaguar Forums would like to thank John ( Caldoofy ) once again for his generosity shown to the memberbase. ___________________ Good Luck to everyone. Graham |
Using RANDOM.ORG to generate a random draw sequence, the results are as follows:
The lucky winner of the Stage 1 Air Intake Tube Kit is: 41. Michael Star Congratulations to Michael (PM on the way) and a huge thank you to John (Caldoofy) for making this Kit available. Remember, if you didn't win you can still order the Intake Kit through Caldoofy. Here is the Participant List from post #2 in the order generated by RANDOM.ORG: 41. Michael Star 9. The Puurfect Fast Cat 3. snknet 11. XJRTrooper 94. mattijs 54. tonyu47 15. georgekale 53. maxthrottle 27. 58steve 55. utayogi 83. STRaightJAGin 8. Cambo351 13. ryejag 57. Cat Man Do 43. TomSTR05 81. Broncobra 47. luv2fly 34. FirehawkMike 33. brianbrouillette 31. Russel11 58. FreakingAwesomeJag 62. Casper 28. michal 91. Zazzy 67. dvsadam 7. v12mike 88. MyBlackCat 74. amoeba 50. Seth 60. dkt388 42. chrisz 79. NormB 56. V40TC 59. harley47 16. ONEsicJAG 87. thwbait 75. LSPC 19. crocodile62 64. Damiannc 14. pcar00 61. MarcB 2. magmedia 6. 200SType40 66. sweitznr 48. biffo17 39. JagSTR2004 65. qmusmar 76. QuikCat 92. aero-hot 36. CoventryFlagship 12. StypeRowner 1. Trevor 68. GT42R 72. kh3859 69. 03Jagg 32. hunter34 71. Docuzzie 30. PigletJohn 84. chrisgsemail 23. rickyrich007 25. djdex 70. DMC04XJR 24. Cas 5. Colnago 49. Davey2h 86. bdmpit 20. psg 10. parinbr 45. k2colo 40. shadow99 4. pokey 38. raschwar 85. anindyam 80. hotstr 17. BOB7747 93. Fred09 51. 1320racer 89. Sesso 77. Cruizinstr 21. Popeye 29. Zwolf 82. iBike 90. bklynchris 73. prolepsis 26. JagmadMike 78. Dst1 37. Rojie 46. azgdds 35. dmdz 18. dsetter 44. capt.craw 63. banjobill Timestamp: 2013-09-26 18:59:24 UTC Graham |
