how to replace XJ8 Window Master Switch
Hello,
The window switches of the driver side are faulty, and I want to replace them. Do I have to remove the door panel to replace them or is there any easier way to do it? Regards |
It is a 2008 XJ8 by the way :)
There are two screws directly under the switch thru the handle/armrest.
Remove these and the switch lifts out. Good luck! |
Thank you very much Rrd623
