Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   XJ XJ6 / XJ8 / XJR ( X350 & X358 ) (https://www.jaguarforums.com/forum/xj-xj6-xj8-xjr-x350-x358-28/)
-   -   Jaguar Land Rover diagnostic tool (https://www.jaguarforums.com/forum/xj-xj6-xj8-xjr-x350-x358-28/jaguar-land-rover-diagnostic-tool-126851/)
millenia man Sep 20, 2014 11:00 PM
Hi,
Can I get some opinions on this kit for sale on Ebay?
I know it doesn't have the full subscription, but will it do the following:
Give me abs and chassis codes
allow me to adjust suspension height
option to adjust the door locking modes
diagnose airbag issues
Would appreciate any info from folks who are using this tool.
Thanks,
Don
Jaguar Land Rover Diagnostics Coding Programming Kit Dealer Software IDS SDD JLR | eBay
Don B Sep 20, 2014 11:36 PM
Originally Posted by millenia man (Post 1062073)
Hi,
Thanks,
Don
Hi Don,
I don't have any experience with that kit, but several of us are successfully using the one at the link below:
Promotion JLR Mangoose for Jaguar and Land Rover V138 Support till 2014 Year
The one I bought came with SDD V134. I had previously understood that V131.03 was the latest version that could be used without an active subscription to TOPix, so I purchased that version of the software separately. But after additional research, I installed the V134 software and it's working just fine with WiFi turned off (otherwise it wants to try to log on and update itself). The seller stated that V134 only worked with 2005 vehicles and later, but it's working fine with our 2004 XJR. I don't know about the V138 that the uobd2 is now offering. You should ask them to be sure it will work with your '07.
See this thread for more info:
https://www.jaguarforums.com/forum/g...an-tool-66558/
Note that for V131.03 and V134, and I believe for V138 also, you must run the program in Windows XP 32-bit. I first installed it on an old XP laptop, then after more research I successfully created a Windows XP virtual machine on a Windows 7 laptop, and that's what I'm using now. I haven't worked on the ABS or airbag systems, but I believe SDD has that capability. I have used SDD to recalibrate our air suspension ride height, pull P, B, C and U codes, turn off the automatic setting of the Electronic Park Brake, turn off some of the annoying alarms, etc. It's the dealer-level tool, so if the dealer can do it you probably can too.
Cheers,
Don
doc Sep 21, 2014 12:07 AM
5 Attachment(s)
I just bought this one Wholesale Product Snapshot Product name is DHL Free shipping+22% off!! Original Chip Best Quality FORD VCM IDS Rotunda For Ford&Mazda&Land R0ver&Jaguar,support programming
Only problem installing the software and the plug but the guy has sent me another so here's hoping LOL
ragman1171 Sep 21, 2014 03:53 AM
Hello Don,
I have and use the kit that you listed. I bought mine from the same person even. So far, there has been nothing that I cannot do with it. That's my $0.02
Jason
millenia man Sep 21, 2014 06:35 PM
JLR tool
Thanks for all the input. I have ordered the device that I posted about.
"Ragman" says he's happy with it, that's good enough for me!
Reading some of the other ad's on Ebay, it was hard to tell if others that bought it were successful with the installation and reliability.
I'll update when I have tried the device and software out.
Regards,
Don
ragman1171 Sep 22, 2014 03:08 AM
Regards,
Don
Don,
Thanks for the vote of confidence. Please feel free to contact me with the setup of the software when it comes in if you have questions. I've let the guy know that his instructions are a bit dated and gave him some pointers as to what to adjust. I don't know if he took them or not to date. As a Sr LAN Engineer and have several IT Certifications, to include the VCP (vMware Certified Professional) which came in handy when I received the discs as vMware is the way the software provided is set up. I'll PM you my mobile number and email.
R,
Jason
Xag Sep 22, 2014 02:02 PM
Jason,
Interesting to read you've set it up on a VM. I first installed it direct on XP but since the SDD requires reinstalling from time to time I've yesterday installed it on Oracle Virtualbox.
I'm curious what do you mean by saying this software install is VM based.
Guus
Revonok Oct 8, 2014 09:20 AM
Originally Posted by jmeres (Post 1074223)
I bought mine with V138 from the moderator's first link. It works ok with my 05 xk, just need to do some research to install it in xp mode. BTW, I got it for $46, 7% during their 7th anniv. celebration and then won $10 in anniv lucky draw.
So am I understanding correctly that for 49.99 you got the Mongoose cable AND the IDS/SDD software? I was under the impression that it cost loads of money but maybe I'm confused (I need more coffee)
Don B Oct 8, 2014 10:23 AM
This is a clone version and yes, that is the correct price. Obviously, you will receive no warranty support from Jaguar on either the cable or software, but several members are using that setup successfully.
ragman1171 Oct 8, 2014 02:06 PM
Originally Posted by jmeres (Post 1074221)
I guess he means the software is in the VM and is independent from the rest of the computer.
Xag,
The system I picked up is not the SDD software alone. It is embedded in a VM package that the DVDs have. Essentially, you're installing a vMware image that has an XP OS and the SDD software already installed on it. Unless you can get the .msi for the SDD, then you won't be able to install it onto your own VM inside Windows 7/8. I hope that helps.
Rags
Revonok Oct 8, 2014 02:25 PM
Is anyone able to confirm that the V.138 Software works with 2004 X350's?
Don B Oct 8, 2014 02:54 PM
V134 is working just fine for me but I haven't tried V138. If you get the cable and software from uobd2.net, just ask them if they might be willing to supply you with both V138 and V134 just to be safe.
Revonok Oct 8, 2014 08:57 PM
Now that I'm home from work and had some time I read through all 24 pages of the "Cloned dealer scan tool" thread and think I'm going to give the "Mangoose" a shot.
I emailed uobd2 and they said they would supply me with v134 instead of v138 if that's what I would like.
Don B Oct 8, 2014 09:35 PM
I wonder if you can talk them into supplying both versions? They supply the software on burned CD-Rs or DVD-Rs, so it won't cost them much to include both discs. That way you could try V138 and let the rest of us know if it works, and if not, uninstall it and install V134. :)
Revonok Oct 9, 2014 09:46 AM
I'm about to order mine and I'll definitely request that; I'll let you know how it goes.
ragman1171 Oct 9, 2014 09:58 AM
I'd like to know as well please!
Revonok Oct 9, 2014 02:16 PM
I've just ordered mine and should be recieving V134 & V138, I'm hoping it doesn't take a month to arrive but when it does I'll let you all know if 138 is working with 2004's.
ragman1171 Oct 9, 2014 07:43 PM
I paid the $51 USD for the expedited shipping and it still took almost two week from GB to Virginia.
A side note to the VM that it installs, before you launch the SDD software in it, set the date of the VM back to 1 JULY 2011 and then restart the VM. After that, launch the SDD. If you launch it and it's into August, it'll search for a internet connection to update the software and as you don't have an internet connection (no NIC), it won't be able to and it will cease functionality the later the date gets.
It's not hard to do and doesn't take long. I have a 500GB SSD in my laptop, so it moves quickly as well. Just and FYI
camuar Oct 9, 2014 10:10 PM
Originally Posted by jmeres (Post 1074220)
Some tools only work on xp, so if you want to install it on win7 or win8, you will need a VM.
I agree jmeres, Indeed it is, Some diagnostic tools work on xp system more stable, but you can also try win7 or win8 system, preferably using virtual machine.
Revonok Oct 10, 2014 08:30 AM
Thanks for the heads up Jason! I hope mine doesn't take too long since I have a whole week off coming up to play with it, then it's back to living in the office.
I was planning on writing a How-to guide on getting everything installed and running both on XP and W7 through a VM to hopefully help out some of the members here who may not be as tech savvy.
On a side note it's great to see another Network engineer on the forums! I've been a Cisco Network Engineer for a long time now and computers/technology were my first passion before I found my Jag :icon_steer:
© 2026 MH Sub I, LLC dba Internet Brands
