New front sway bushings - how tight?
Old May 30, 2019 | 10:34 PM
exiledbrit's Avatar
Default New front sway bushings - how tight?
I got the bushes in and tightened down the clamps. The bushes were well greased before installation but I am wondering if the sway bar can be too tight. I can raise and lower it by hand with a lot of force. I imagine it will loosen up with a little wear. Anybody have advice on this before I bolt in the new drop links?
Many thanks
Steve
Old May 31, 2019 | 07:24 AM
Wingrider's Avatar
Seldom use a torque wrench myself, unless i am inside of a motor.
The size of fastener determines the amount of torque in most cases.
Old May 31, 2019 | 07:43 AM
jackra_1's Avatar
Default From the WS Manual
Description Nm lb-ft lb-in
Steering gear to subframe retaining bolts 100 74 -
Stabilizer bar link retaining nut 43 32 -
Stabilizer bar link retaining nut and bolt 70 52 -
Stabilizer bar clamp retaining bolts 55 41 -
Rear lower arm ball joint retaining nut 92 68 -
Front and rear lower arm to subframe retaining nut and bolt 175 129 -
Front lower arm to rear lower arm retaining nut and bolt A A A
Upper arm ball joint retaining nut 90 66 -
Upper arm to body retaining nuts and bolts 47 35 -
Air spring assembly to lower arm retaining bolt 175 129 -
Tie-rod end to wheel knuckle retaining nut 75 55 -
Wheel hub and bearing to wheel knuckle retaining bolts 90 66 -
Exhaust manifold to cylinder head retaining nuts (3.0l only) 20 15 -
Dipstick tube retaining bolt 10 7 -
Engine mount lower retaining nut 55 41 -
Front subframe front retaining bolt 200 148 -
Front subframe rear retaining bolt 115 85 -
Wheel and tire retaining nuts 125 92 -
Hydraulic control unit retaining bolts 9 - 80
A = refer to the procedure for the correct torque sequence - - -
Old May 31, 2019 | 07:46 AM
Wingrider's Avatar
Better answer than mine, much more accurate.
Old May 31, 2019 | 01:44 PM
exiledbrit's Avatar
Thanks guys. I couldn't get my torque wrench in there but I reckon my mechanics hand memory has it about right. It loosened up some after a few pressups. Got my new drop links in, wheel well liners in and am about to paint the lower front crossmember after wire brushing. Everything looking good for a test drive tonight
Steve
Reverend Sam
Mar 13, 2019 06:38 AM
04xtype04
May 4, 2014 09:27 PM
fixit4u2
Mar 14, 2011 09:14 PM
Dimension247
Nov 28, 2010 03:11 AM
bojangles
Jan 16, 2008 07:43 PM
