P050B and stall after ACM installation.(Resolved)
Yes I installed my audio connectivity module (it works as expected) but I now have idle issues and a check engine light with P050B error code. The idle surges between 500 and 800 rpm. I took it for a drive and it stalled when I came to a stop.
It appears that there is a TSB (30313) for this, I could only find summaries. Any help would be appreciated! |
Okay so I have the best indie mechanic ever (even though he is 800 miles away)...called him after I posted and he answered right away, on a Sunday! Per the TSB the ECM needs to be reflashed (this appears to be unrelated directly to the ACM install but apparently this may have something to do with disconnecting the battery).
So in the meantime he gave me the following procedure. I am sure this is in the forum somewhere but I had a tough time searching. 1. Make sure the A/C is off. 2. Hard reset - disconnect both battery terminals hold them together for 15-20 sec. reconnect the positive, then as cleanly and smoothly as possible connect the negative. 3. Start the car with your foot off the brake (DO NOT TOUCH ANYTHING) - at this point the car was still idling wildly, continue to let it run for 2 minutes, remakebly the idle smooths out. Again, do not touch anything! 4. When the idle stabalize at a normal rpm reset the parking brake (and windows) 5. Switch the A/C on and do not adjust anything, let it run for an additional 3 minutes. 6. Test drive - everything checked out fine. and so far so good (fingers crossed/knock wood) I hope the solution to my little episode will help others, I was in a bit if a panic, to put it mildly. |
Yep...... freaked me out the first time I disconnected the battery. As you say just leave it and it eventually sorts itself out. Does your XK not do the same thing if you disconnect the battery ? My '00 XJR used to also do something weird when you reconnected the battery, so I wasn't completely surprised when the '06 did weird stuff too.
That will certainly make you leery of disconnecting the battery. Almost sounds like something you would expect from a BMW:rolleyes:
Other than that, how was the play Mrs. Lincoln? Any impressions about the ACM, in regards to installation or performance? I hope to move forward with the same in the next couple of weeks so I am curious if you are happy with it. Also, where did you source the module? |
Originally Posted by Sarc
(Post 748796)
Originally Posted by HJ808
(Post 749049)
What are the pitfalls with the glovebox?
I assume that the ACM is the once again available c2c40513. Does it appear that the ACM, now that it has been "re-released" after being unavailable for some period, already has the newest Dension firmware as described in this post from another thread? jahummer Veteran Member 2008 Jaguar XK-Series My Garage Join Date: Dec 2008 Location: Florida Posts: 1,172 Thanks: 119 Thanked 58 Times in 53 Posts The color change you mention has nothing to do with the ACM. The 2010 NAV disc has a firmware update for the head unit that changed the background color of the home screen and the logo a well as some minor function changes. The ACM DB2 update is indeed through the USB using a thumb drive. Download the DB2 version here: http://support.dension.com/support-c...root=12&id=110 The update is not from/for Jaguar, rather for the Gateway 500 main processor which is also used in other vehicles from Mercedes, BMW, etc. The Audio screen will change slightly with changed functionality of the CD 1-4 buttons and button 6. I have an old iPod, but I have not used it in a while, but I can tell you with the iPhone 4 as well as the iPod touch you can now use the touch screen as well as any music apps, which I was unable to before the update. This may answer your question with your iPod: 1. Gateway UI (Controls via head unit) Select disc 6, track 3 and then press and hold FF button for approx. 2-3 seconds. 2. iPod UI mode: (Controls via iPod's touchwheel) Select disc 6, track 2 and then press and hold FF button for approx. 2-3 seconds. |
Originally Posted by MarcB
(Post 748629)
UPDATE: According to my indie (who has the car now) the behavior is not normal and the reflash as prescribed in TSB 30313 is the cure.
As far as pitfalls of the glovebox: It was just physically difficult to remove and reinstall. It does have the new 1.9 firmware but I do not have control from the iPod. I have not had a chance to reset it nor did I see the instructions about the iPod UI to vehicle GUI switch. I will check it out when I get the car back today. |
(Post 748629)
So in the meantime he gave me the following procedure. I am sure this is in the forum somewhere but I had a tough time searching. 1. Make sure the A/C is off. 2. Hard reset - disconnect both battery terminals hold them together for 15-20 sec. reconnect the positive, then as cleanly and smoothly as possible connect the negative. 3. Start the car with your foot off the brake (DO NOT TOUCH ANYTHING) - at this point the car was still idling wildly, continue to let it run for 2 minutes, remakebly the idle smooths out. Again, do not touch anything! 4. When the idle stabalize at a normal rpm reset the parking brake (and windows) 5. Switch the A/C on and do not adjust anything, let it run for an additional 3 minutes. 6. Test drive - everything checked out fine. and so far so good (fingers crossed/knock wood) I hope the solution to my little episode will help others, I was in a bit if a panic, to put it mildly. Is there an official source for this procedure? |
(Post 749049)
Originally Posted by a4500435
(Post 870183)
What do you mean by 'reset the windows'
2 Attachment(s)
(Post 870183)
So this is the way to deal with the P050B code? What do you mean by 'reset the windows'?
Is there an official source for this procedure? For official sources I suggest you check out http://www.jagdocs.com/. I am not affiliated in any way other than being a customer, but you can purchase workshop manuals, TSBs and other official documents relatively inexpensively. |
