Timing Cover removal
How exactly do you get the top bolt out of the Power Steering pump so you can remove the timing chain cover on a 2006 XJ8L. This thing is killing me. It was already stripped and I think I going to be force to cut it off unless someone here has a trick. HELP PLEASE!!
Here's my writeup on power steering pump removal and replacement: https://www.jaguarforums.com/forum/x...ctures-247875/
If memory serves you should be able to use a small 1/4" ratchet to get at the 4 bolts. If you loosen the engine mount bolts you can get some more room by lifting the engine. Factory procedure is to use an engine lifting device; using a floor jack is NOT factory procedure but worked fine for me. Are you doing full timing replacement? |
I re-read your post about getting "the top bolt out" -- just FYI more than the top bolt has to come out; unfortunately both brackets behind the power steering pump and the AC compressor have to come out. There's like 15-16 bolts in total. It was the part of the head gasket job that I cursed the most at. The cover should have been designed differently, it adds a lot of time to the job.
Originally Posted by scooterforever
(Post 2455839)
timing cover on the XK8 is a 5 minute job and all the accessories stay in place |
Thanks Scooter, didnt realize had to take alternator off too.:mad:
Yes i was planning on doing full timing replacement. I figure i am doing it anyway so do it rt
Originally Posted by RodL
(Post 2456024)
I have a leak from my timing cover. Not even bothering at this point. It keeps my metal parts nice and sheen...
