Timing Cover removal
Old Oct 19, 2021 | 03:21 PM
RodL's Avatar
Angry Timing Cover removal
How exactly do you get the top bolt out of the Power Steering pump so you can remove the timing chain cover on a 2006 XJ8L. This thing is killing me. It was already stripped and I think I going to be force to cut it off unless someone here has a trick. HELP PLEASE!!
Old Oct 20, 2021 | 06:50 PM
scooterforever's Avatar
Here's my writeup on power steering pump removal and replacement: https://www.jaguarforums.com/forum/x...ctures-247875/
If memory serves you should be able to use a small 1/4" ratchet to get at the 4 bolts. If you loosen the engine mount bolts you can get some more room by lifting the engine. Factory procedure is to use an engine lifting device; using a floor jack is NOT factory procedure but worked fine for me.
Are you doing full timing replacement?
Old Oct 21, 2021 | 08:12 AM
I re-read your post about getting "the top bolt out" -- just FYI more than the top bolt has to come out; unfortunately both brackets behind the power steering pump and the AC compressor have to come out. There's like 15-16 bolts in total. It was the part of the head gasket job that I cursed the most at. The cover should have been designed differently, it adds a lot of time to the job.
Old Oct 21, 2021 | 08:26 AM
xalty's Avatar
they did that way because there’s really no room
timing cover on the XK8 is a 5 minute job and all the accessories stay in place
Old Oct 21, 2021 | 04:36 PM
RodL's Avatar
Thanks Scooter, didnt realize had to take alternator off too.
Old Oct 21, 2021 | 04:38 PM
RodL's Avatar
Yes i was planning on doing full timing replacement. I figure i am doing it anyway so do it rt
Old Oct 22, 2021 | 08:22 AM
I found the manual to be relatively good at describing the timing component replacement procedure. The specialty tools (crank pulley hold down, timing tools) are very useful and in the case of timing tools critical (there are versions of these tools on eBay). I also found a cheap $30 eBay endoscope (with wifi camera to a smart phone) was very helpful in removing the crank pulley as it's a bit hard to get the tool holes lined up just right with the crank pulley. My crank pulley would not budge until I used six feet of pipe on the breaker bar... crazy torque.
Old Oct 23, 2021 | 06:08 PM
abonano's Avatar
I have a leak from my timing cover. Not even bothering at this point. It keeps my metal parts nice and sheen...
JensenHealey
Feb 1, 2019 01:58 AM
JensenHealey
Jan 12, 2019 11:48 AM
Daim
Jul 30, 2017 10:36 AM
barbeerh
Feb 24, 2014 04:34 PM
Michigan
Jun 30, 2008 07:04 PM
