Trunk Switch badge?
The button on the trunk on my 2005 VDP has seen better days. It has a frosted look to it. I found this on the Welsh Enterprises website:
http://www.welshent.com/images/produ...SW-350x350.jpg What is involved with replacing the emblem? Was the originally back lit? Why does mine look so bad when the rest of that area on the car is perfect? |
See this discussion:
https://www.jaguarforums.com/forum/x...-course-47400/ |
I removed mine don't worry you are not alone, sun fades it I guess
Thanks guys. Just the info I was looking for. Ordering mine today.
Thanks for the heads up.:icon_razz: I had tried to order a replacement soft emblem through Jag 2 years ago and found that the entire push button assby. had to be ordered to access this part. Welsh filled the order today. Talk to Herky. He's got em on a shelf in back of his desk.
It will be a pleasure to replace that dirty old piece. Generally it costs a lot to be so persnickety, but not this time.:icon_teeth: |
Got my new badge and replaced the old one today. Piece of cake, as we say.:icon_razz:
Just for giggles, I cleaned the old one with lacquer thinner with good results. Not like the new one, mind you, but good enough if you are trying to get buy without spending $25. If you try to do this on the car be very careful about getting the lacquer thinner on the paint. You just never know how the paint will react. |
Hey tarhealcracker,
How did you remove the old one and what did you use to secure the new one. I was just noticing tonight how bad mine looked. |
I used a dental pick to hook the badge and gently pulled it off.:icon_razz:
