Upper alternator bolt access
Rather than Auto Zone, for an alternator there's a place here, that rebuilds yours with all new internal parts. The same quality as stock, or better, usually in a single day, or buy the parts and do it yourself. Great hole in the wall place, that's been there forever, and has a great reputation, for fixing your electrical, as well as many other issues, the first time, at a FAIR price.
I will know by the end of the week. Fedex will deliver the alternator Tuesday.
If its early enough I will get Autozone to test it, with a printed out put hopefully,
Tuesday.
Can you provide contact details of the place?
Automotive Electric Service - Auto Parts & Supplies - 65 Glendale Ave ...
https://www.yelp.com › Automotive › Auto Parts & Supplies
Photo of Automotive Electric Service - Akron, OH, United States. Photo of ... Yelp users haven't asked any questions yet about Automotive Electric Service.
There You GO!!!
There You GO!!!
#28
Received 2,580 Likes
Have you searched the local area near you for an automotive electrical shop? They can usually have an alternator or starter refurbished the same day.
#30
#31
#32
Wasted a couple of hours this morning taking my original alternator to this alternator rebuild shop.
They looked at it and said they could not get spare parts for it thats after I told them over the phone what make it was etc!
They also said they could not test it AND tell me what the voltage output is.
Autozone tested it and said that it "passed" but could not tell me what the output voltage is. Same on the unit I got from Autozone so returned it there and then.
At this point I am seriously wondering if my problem is not the alternator.
#33
#34
Which if accurate is way low.
With the new oem alternator with a voltage set point of 14.18 volts I was getting:
13.85 volts with engine running at idle and 12.78 volts across battery terminals with engine off.
The test sheet that came with the alternator says "voltage regulator set point" is 14.18 volts.
This was using a digital multimeter.
I currently have questions out to two alternator vendors asking what the voltage set point is on their recommended alternators.
#35
