water coolant system
can anyone tell me how many litres of water are used to fill water coolant system on x350 v6 been looking but unable to find this information
I need to empty the system to replace some perished pipes.. Hope some can help also how many litres of antifreeze would you advise any help would be much appreciated:icon_wink: |
Panther, you will be in the neighborhood of 8-10 liters/quarts of fluid. So, get yourself 3 one gallon (3.78 liter) bottles of 50/50 pre-mix antifreeze and keep pouring in until the system is at the proper level.
To maintain the 50/50 ratio, pre-mixed coolant should not be further diluted with water or anything else.
1 Attachment(s)
Welcome to the forum panther222,
I've moved your question from General Tech Help to X350 forum. This is the place to post tech questions about your model. Here is and extract from the X350 Workshop Manual specification section showing the refill capacity: https://www.jaguarforums.com/forum/a...p;d=1408804235 Use a 50/50 mixture of recommended coolant/distilled water for refilling. Please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum. Graham |
