Whats going on here?
This morning while driving to work and then back home I kept getting an error message on my dashboard/speedo read out that said "Cruise Control Not Available" Then a little later the Adaptive Cruise Control would light up and the readout would read "driver interference" then jump back to "cruise control not available" Whats going on? FYI, I have a 2004 XJR with lower mesh on my car that's been on for over a year without an issue.
Take the mesh off and see if that makes a difference. Could be interference or a malfunction of the radar.
Originally Posted by albert328gts
(Post 444463)
Good luck! |
No not the lower mesh grill...
Well I finally took off the lower grill and cleaned up a bit of the dust in there and before I could get the car out of the driveway it happened again. Now I have no idea what this could be...:confused:
Could be an anomaly with the wheel speed counter on one of the wheels. These are also used for the anti-lock brake system. However, this is only a guess.
cruise
I have had the message cc not available twice in three years. Both times was after the car had sat for weeks while I was out of town. Drove for a long drive and shut the car off. No message after that. I figured the batt must be low. I do not have the radar cruise though.
Chad |
(Post 444877)
This could ultimately require the Jaguar diagnostic equipment to really see what the system detects. The system is complicated and seemingly unconnected things can mess with you. A good example I have run into is a guy changing his wheel size and not having the car reconfigured to that size. The car [wheel] speed says one thing, and the ACC constantly calculates the speed of things coming at it. Well, if it always sees things approaching at something DIFFERENT than road speed, it says, "this can't be right, I must not be able to see, my sensor must be blocked". Bingo, a "Sensor Blocked" message. Good luck! |
Yes and the car does have 20's
On it now, for as long as I have owned it, it has had both the lower grill and the 20" BBS. But I never turn either one of them on? Not the cruise control nor the ACC. Sounds like a visit to the dealer...
