(Yet another) Faulty Parking Aid Question
Subscribe
May 20, 2023 | 03:05 AM
Folks,
Parking sensor questions have been asked to destruction, but I promise (sort of?) this is not one of them [img]data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7[/img]
Front: So; dealing with the usual parking aid issues; looked up the fault codes, replaced the outer right front sensor, and everything now works like a champ.
Rear: not so much luck(ish). Replaced the faulty sensor, system worked once, then back to the dredded long beep.
Resistance Checks: replacement parts pin 1 - 2: 10KΩ. Existing Jaguar OEM parts: open circuit on every single rear sensor. Reading with a bench ohmmeter, resistance is about 1.1MΩ
My replacement part is the SNG Barratt (C2C29376XXX*) states: Front/Rear Parking sensor.
Looking up the Jag EPC, I have two part numbers listed: Front: C2C29376XXX Rear: C2C29377XXX
My question: are all sensors, front/rear the same ? and if they weren't, why would SNG sell their replacement as front/rear sensor?
Thanks in advance.
Reply 0
May 20, 2023 | 06:07 AM
AFIK all sensors are the same except one no you quoted is straight and the other part no is 90 degrees.
Google the no's in Images to see them
Reply 1
May 20, 2023 | 07:50 AM
Quote: AFIK all sensors are the same except one no you quoted is straight and the other part no is 90 degrees.
Thanks a lot for your reply @meirion1.
Yes, you're right: the apparent difference is the 90 deg. vs straight connector. I was just a bit sceptical when reading the resistance values, but comforted by the listing on SNG's and the EPC's entries, listing the same sensor as front and rear.
Ah well; looks like another SNG order to get two extra sensors - I have two new ones already.
Thanks again.
Reply 0
May 20, 2023 | 02:47 PM
BTW
To get rid of the beeping pro tem pull a fuse in the cabin box.
Check your OM for fuses ie which one.
Bought my Jag in Mill Hill about 16 years ago!
Reply 0
May 21, 2023 | 02:22 PM
The PAM stores DTCs I suggest you use them.
ohmeter = not a reliable diag tool. passing a resistance test is just that, passing a resistance test it does not mean the part is good
Reply 0
Subscribe
Currently Active Users (1)
